Introduction
Go to step 1 ↓Follow this guide to replace the optical drive on your Sony Playstation 4.
On 1XXX series models of the PS4, the optical drive daughterboard and the motherboard are paired. If your daughterboard's broken, you'll have to replace the motherboard.
You can replace the the optical drive assembly by itself, but the replacement assembly must be compatible with the your optical drive daughterboard.
Unplug your PS4 before beginning any repairs.
Tool used on this step:Tweezers$4.99
Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
Remove the four 7.2Â mm T8 Torx security screws on the back of the PS4.
Remove three 9.7 mm-long TR8 Torx security screws.
Remove two 41 mm-long Phillips screws and brackets.
Use the tip of a spudger to disconnect the antenna cable from the motherboard.
Use your fingernail to press down on the metal release lever of the ribbon cable on top of the optical drive.
Use your fingers or a pair of tweezers to disconnect the ribbon cable by pulling on the black tab.
Remove the four screws securing the optical drive.
Three 9.7Â mm Torx screws
One 6.2 mm Phillips screw
📌To reassemble your device, follow the above steps in reverse order.
205 other people completed this guide.
74 Guide Comments
This was a great help after my 2 yr old put a coin in my PS4. However when following the steps backwards I got to step 7 which says 'Remove the 5 wire plug attached from the power supply to the motherboard' & couldn't see how to reattach it. I then noticed it looks like I've pulled the whole plastic white casing/plug holder (within the orange rectangle) off the mobo rather than just the plug from the casing. Although the pic looks like the plastic casing does come off the mobo as it's at an angle (maybe why I pulled the whole thing out or maybe I did it right).
I'm thinking I've made a mistake is because now I cant see anywhere that I can 'plug' the 5 L shaped wires on the bottom of the plastic casing back onto the mobo. Plus where they used to be attached there's now 5 tiny silver rectangles on the mobo (2 opposite 3), so I guess these 5 wires were some how adhered to those mobo rectangles by a conductive adhesive of some sort.
Any suggestion for the best repair method would be appreciated.
Thanks
Is anyone there who try to change the optical drive without change the Motherboard in the same time ? And does it run ?
Thanks for your help.
How about a guide for replacing just the laser unit instead of the whole drive?
I changed the drive with its motherboard, when I want to update the system, an error message appears:
CE-42116-8 .
