PlayStation 4 Motherboard Replacement
    1. PlayStation 4 Motherboard Replacement, Remove the hard drive cover: step 1, image 1 of 3 PlayStation 4 Motherboard Replacement, Remove the hard drive cover: step 1, image 2 of 3 PlayStation 4 Motherboard Replacement, Remove the hard drive cover: step 1, image 3 of 3
      • Grip the PS4 with both hands along the gap in the top cover.
      • Push the glossy side of the top cover with your thumbs until it pops to the side.
      • Lift the glossy top cover up and back to remove it from the PS4.
      Ask FixBot
    2. PlayStation 4 Motherboard Replacement, Remove the hard drive bracket screw: step 2, image 1 of 2 PlayStation 4 Motherboard Replacement, Remove the hard drive bracket screw: step 2, image 2 of 2
      • Use a Phillips screwdriver to remove the 6.5 mm screw securing the hard drive bracket to the enclosure.
      Ask FixBot
    3. PlayStation 4 Motherboard Replacement, Remove the hard drive bracket: step 3, image 1 of 3 PlayStation 4 Motherboard Replacement, Remove the hard drive bracket: step 3, image 2 of 3 PlayStation 4 Motherboard Replacement, Remove the hard drive bracket: step 3, image 3 of 3
      • Pull the hard drive bracket out of the enclosure.
      • Be careful not to drop the hard drive. The internal components are fragile and are susceptible to damage by sudden shock.
      Ask FixBot
    1. PlayStation 4 Motherboard Replacement, Flip over the PS4: step 4, image 1 of 1
      • Flip the PS4 upside-down with the back side facing towards you.
      Ask FixBot
    2. PlayStation 4 Motherboard Replacement, Remove the warranty stickers: step 5, image 1 of 3 PlayStation 4 Motherboard Replacement, Remove the warranty stickers: step 5, image 2 of 3 PlayStation 4 Motherboard Replacement, Remove the warranty stickers: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
      Ask FixBot
    3. PlayStation 4 Motherboard Replacement, Remove the plastic screw covers: step 6, image 1 of 2 PlayStation 4 Motherboard Replacement, Remove the plastic screw covers: step 6, image 2 of 2
      • Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
      Ask FixBot
    4. PlayStation 4 Motherboard Replacement, Remove the rear case screws: step 7, image 1 of 2 PlayStation 4 Motherboard Replacement, Remove the rear case screws: step 7, image 2 of 2
      • Remove the four 7.2 mm T8 Torx security screws on the back of the PS4.
      Ask FixBot
    5. PlayStation 4 Motherboard Replacement, Remove the lower case: step 8, image 1 of 2 PlayStation 4 Motherboard Replacement, Remove the lower case: step 8, image 2 of 2
      • Use your thumbs to lift the lower case up and off the PS4.
      • The lower case is held into place by plastic clips. You may need to use significant force to release the lower case.
      Ask FixBot
    6. PlayStation 4 Motherboard Replacement: step 9, image 1 of 2 PlayStation 4 Motherboard Replacement: step 9, image 2 of 2
      • Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
      • If your connector feels stuck, use a spudger to gently pry the connector out.
      Ask FixBot
    1. PlayStation 4 Motherboard Replacement, Remove the power supply unit: step 10, image 1 of 2 PlayStation 4 Motherboard Replacement, Remove the power supply unit: step 10, image 2 of 2
      • Remove three 9.7 mm-long TR8 Torx security screws.
      • Remove two 41 mm-long Phillips screws and brackets.
      Ask FixBot
    2. PlayStation 4 Motherboard Replacement: step 11, image 1 of 3 PlayStation 4 Motherboard Replacement: step 11, image 2 of 3 PlayStation 4 Motherboard Replacement: step 11, image 3 of 3
      • Lift the power supply straight up and out of the PS4.
      • The power supply is held firmly in place by prongs on the left side. It may take multiple attempts to remove it.
      • During reassembly, ensure the prongs are aligned, then press the power supply into place.
      Ask FixBot
    1. PlayStation 4 Motherboard Replacement, Remove the Wi-Fi antenna: step 12, image 1 of 2 PlayStation 4 Motherboard Replacement, Remove the Wi-Fi antenna: step 12, image 2 of 2
      • Use the tip of a spudger to disconnect the antenna cable from the motherboard.
      Ask FixBot
    2. PlayStation 4 Motherboard Replacement: step 13, image 1 of 3 PlayStation 4 Motherboard Replacement: step 13, image 2 of 3 PlayStation 4 Motherboard Replacement: step 13, image 3 of 3
      Buy
      • Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides.
      Ask FixBot
    3. PlayStation 4 Motherboard Replacement: step 14, image 1 of 3 PlayStation 4 Motherboard Replacement: step 14, image 2 of 3 PlayStation 4 Motherboard Replacement: step 14, image 3 of 3
      • Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable.
      Ask FixBot
    4. PlayStation 4 Motherboard Replacement: step 15, image 1 of 2 PlayStation 4 Motherboard Replacement: step 15, image 2 of 2
      • Remove the 9.7 mm Torx security screw securing the antenna.
      Ask FixBot
    5. PlayStation 4 Motherboard Replacement: step 16, image 1 of 2 PlayStation 4 Motherboard Replacement: step 16, image 2 of 2
      • Remove the Wi-Fi antenna.
      Ask FixBot
    1. PlayStation 4 Motherboard Replacement, Disconnect the optical drive: step 17, image 1 of 3 PlayStation 4 Motherboard Replacement, Disconnect the optical drive: step 17, image 2 of 3 PlayStation 4 Motherboard Replacement, Disconnect the optical drive: step 17, image 3 of 3
      Buy
      • Use your fingernail to press down on the metal release lever of the ribbon cable on top of the optical drive.
      • Use your fingers or a pair of tweezers to disconnect the ribbon cable by pulling on the black tab.
      • You do not need to press the metal lever when inserting the ribbon cable back in. You will hear a click once it is fully inserted.
      Ask FixBot
    2. PlayStation 4 Motherboard Replacement: step 18, image 1 of 3 PlayStation 4 Motherboard Replacement: step 18, image 2 of 3 PlayStation 4 Motherboard Replacement: step 18, image 3 of 3
      • Use your fingernail to press down the metal release lever for the ribbon cable connected to the motherboard.
      • Set the ribbon cable aside for reassembly.
      Ask FixBot
    3. PlayStation 4 Motherboard Replacement: step 19, image 1 of 2 PlayStation 4 Motherboard Replacement: step 19, image 2 of 2
      • Use your fingers or a pair of tweezers to disconnect the optical drive cable from the motherboard.
      Ask FixBot
    4. PlayStation 4 Motherboard Replacement: step 20, image 1 of 3 PlayStation 4 Motherboard Replacement: step 20, image 2 of 3 PlayStation 4 Motherboard Replacement: step 20, image 3 of 3
      • Use your fingers or a pair of tweezers to remove the optical drive cable from the cable guides that hold it in place.
      Ask FixBot
    5. PlayStation 4 Motherboard Replacement, Remove the optical drive: step 21, image 1 of 2 PlayStation 4 Motherboard Replacement, Remove the optical drive: step 21, image 2 of 2
      • Remove the four screws securing the optical drive.
      • Three 9.7 mm Torx screws
      • One 6.2 mm Phillips screw
      Ask FixBot
    6. PlayStation 4 Motherboard Replacement: step 22, image 1 of 2 PlayStation 4 Motherboard Replacement: step 22, image 2 of 2
      • Lift the optical drive straight up and out of the PS4.
      Ask FixBot
    1. PlayStation 4 Motherboard Replacement, Remove the upper case: step 23, image 1 of 2 PlayStation 4 Motherboard Replacement, Remove the upper case: step 23, image 2 of 2
      • Remove the two 9.7 mm Torx screws securing the upper case.
      Ask FixBot
    2. PlayStation 4 Motherboard Replacement: step 24, image 1 of 3 PlayStation 4 Motherboard Replacement: step 24, image 2 of 3 PlayStation 4 Motherboard Replacement: step 24, image 3 of 3
      • Lift the upper case up and back to remove it from the PS4.
      • The upper case in held in place by plastic tabs on the front side. It will take significant force to separate them.
      Ask FixBot
    3. PlayStation 4 Motherboard Replacement, Remove the upper EMI shield: step 25, image 1 of 2 PlayStation 4 Motherboard Replacement, Remove the upper EMI shield: step 25, image 2 of 2
      • Remove the twelve 9.7 mm Torx screws securing the upper EMI shield.
      Ask FixBot
    4. PlayStation 4 Motherboard Replacement: step 26, image 1 of 3 PlayStation 4 Motherboard Replacement: step 26, image 2 of 3 PlayStation 4 Motherboard Replacement: step 26, image 3 of 3
      • This step shows you how to properly unscrew the pressure plate.
      • Remove the two 15.6 mm Phillips screws.
      • Gradually unscrew the pressure plate by turning each screw one half turn at a time.
      • Alternate between the two screws to maintain even pressure on the pressure plate.
      • Do not unscrew one side completely before unscrewing the other side or you may damage the processor.
      Ask FixBot
    5. PlayStation 4 Motherboard Replacement: step 27, image 1 of 1
      • Remove the pressure plate.
      Ask FixBot
    6. PlayStation 4 Motherboard Replacement: step 28, image 1 of 2 PlayStation 4 Motherboard Replacement: step 28, image 2 of 2
      • Remove the upper EMI shield.
      Ask FixBot
    7. PlayStation 4 Motherboard Replacement, Remove the motherboard: step 29, image 1 of 2 PlayStation 4 Motherboard Replacement, Remove the motherboard: step 29, image 2 of 2
      • Insert the flat end of a spudger in between the fan cable and the motherboard.
      • Twist the spudger to lift the connector straight up and disconnect it from the motherboard.
      Ask FixBot
    8. PlayStation 4 Motherboard Replacement: step 30, image 1 of 2 PlayStation 4 Motherboard Replacement: step 30, image 2 of 2
      • Grab the edge of the motherboard on the front of the PS4.
      • Lift the motherboard until the USB ports clear the PS4 case.
      Ask FixBot
    9. PlayStation 4 Motherboard Replacement: step 31, image 1 of 3 PlayStation 4 Motherboard Replacement: step 31, image 2 of 3 PlayStation 4 Motherboard Replacement: step 31, image 3 of 3
      • Lift the motherboard out from the PS4.
      • Apply a new layer of thermal paste to the processor before installing a motherboard using this guide.
      • Failure to properly install new thermal paste will cause your PS4 to overheat.
      • Insert the I/O side of the Motherboard in first, then lower the other side in.
      Ask FixBot
223 other people completed this guide.
Sam Omiotek
100,913 Reputation
289 Guides authored
19 Guide Comments
Regarding the three wire plug in step 20 - is there a good way to repair this piece if, say, you pulled the wires out of the connector by accident? is there a place to get a replacement part?
Ryan Statz - Reply Share
I have tried to replace the hdmi port however being somewhat of an idiot I slipped and knocked off onto the little black squares just behind the port on the left hand side. Does anyone know what these are?
Geoff Parker - Reply Share
contacts of the motherboard
lillarrypimp1993 - Reply Share
You may be talking about capacitors that are critically important for the unit to function.
South30 - Reply Share
Past 24 Hours: 36
Past 7 Days: 291
Past 30 Days: 1,227
All Time: 345,322
