Up to 20% off select tools
PlayStation 4 Hard Drive Replacement
Views: 214K
View statistics:
Past 24 Hours:
57
Past 7 Days:
384
Past 30 Days:
1,545
All Time:
214,237
Comments: 23
7 comments on steps, 16 guide comments.
Go to guide comments
Completed: 255
255 people have marked this guide "completed." Will you be next?
Favorites: 97
97 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace the hard drive on your Sony Playstation 4. If you’re upgrading the hard drive and want to keep your saved game data and settings, be sure to back up the data to a separate external storage device before beginning this procedure.
Unplug your PS4 before beginning any repairs.
    1. PlayStation 4 Hard Drive Replacement, Remove the hard drive cover: step 1, image 1 of 3 PlayStation 4 Hard Drive Replacement, Remove the hard drive cover: step 1, image 2 of 3 PlayStation 4 Hard Drive Replacement, Remove the hard drive cover: step 1, image 3 of 3
      • Grip the PS4 with both hands along the gap in the top cover.
      • Push the glossy side of the top cover with your thumbs until it pops to the side.
      • Lift the glossy top cover up and back to remove it from the PS4.
      Ask FixBot
    2. PlayStation 4 Hard Drive Replacement, Remove the hard drive bracket screw: step 2, image 1 of 2 PlayStation 4 Hard Drive Replacement, Remove the hard drive bracket screw: step 2, image 2 of 2
      • Use a Phillips screwdriver to remove the 6.5 mm screw securing the hard drive bracket to the enclosure.
      Ask FixBot
    3. PlayStation 4 Hard Drive Replacement, Remove the hard drive bracket: step 3, image 1 of 3 PlayStation 4 Hard Drive Replacement, Remove the hard drive bracket: step 3, image 2 of 3 PlayStation 4 Hard Drive Replacement, Remove the hard drive bracket: step 3, image 3 of 3
      • Pull the hard drive bracket out of the enclosure.
      • Be careful not to drop the hard drive. The internal components are fragile and are susceptible to damage by sudden shock.
      Ask FixBot
    1. PlayStation 4 Hard Drive Replacement, Remove the hard drive: step 4, image 1 of 2 PlayStation 4 Hard Drive Replacement, Remove the hard drive: step 4, image 2 of 2
      • Remove the two 7.2 mm screws from the right side of the hard drive tray.
      Ask FixBot
    2. PlayStation 4 Hard Drive Replacement: step 5, image 1 of 2 PlayStation 4 Hard Drive Replacement: step 5, image 2 of 2
      • Remove the two 7.2 mm screws from the left side of the hard drive tray.
      Ask FixBot
    3. PlayStation 4 Hard Drive Replacement: step 6, image 1 of 2 PlayStation 4 Hard Drive Replacement: step 6, image 2 of 2
      • Remove the hard drive from the hard drive tray.
      Ask FixBot
You will need to reinstall the PS4 operating system after you replace your hard drive. Follow Sony’s instructions to initialize your PS4 and reinstall system software.
255 other people completed this guide.
Author
with
Sam Omiotek
101,895 Reputation
289 Guides authored
16 Guide Comments
This article needs to be vetted. There is a very specific type of hard drive needed for this machine. Also, the machine will need to be backed up to either the PS Network(for PS Plus members) or a removable storage device. Additionally, the latest system update must be available after the new hard drive is installed. Below is an excellent article for this procedure.
http://www.ign.com/wikis/playstation-4/H...
Kenneth Stockman - Reply Share
can I take out my 500 gig and put in a 1 tb or no ?
Phil manwarren - Reply Share
Hey Phil,
Yes, you can. I have successfully replaced the original hard drive with a 2TB hard drive I purchased. Just make sure you buy the correct type of hard drive. I recommend using the article Kenneth has linked above in the comment section: http://www.ign.com/wikis/playstation-4/H...
I backed up my saved data on the PS network instead of using an external hard drive and that worked great.
Enjoy the extra storage!
Joel Praino - Reply Share
Yes you can upgrade to 1TB or even bigger. Last PS4 firmware update was in august, and it supports storage up to 4TB. You can also use bigger storage but it may result in error.
You can update 2.4-internal HDD or use something like Nyko data bank to use 3.5 inch drives. Also external hard drives is an option, but in order to use them you will need to install the software and games on it.
ps4 hard drives:
http://hddmag.com/2016/07/top-7-best-ps4...
http://www.ryli.net/ps4-hard-drive-guide...
janis kalnins - Reply Share
Past 24 Hours: 57
Past 7 Days: 384
Past 30 Days: 1,545
All Time: 214,237
