PlayStation 3 Slim Heat Sink Replacement
  1. PlayStation 3 Slim Heat Sink Replacement, Top Cover: step 1, image 1 of 1
    • Turn the PS3 over and lay it on its backside.
    • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
    • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
  2. PlayStation 3 Slim Heat Sink Replacement: step 2, image 1 of 2 PlayStation 3 Slim Heat Sink Replacement: step 2, image 2 of 2
    • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
  3. PlayStation 3 Slim Heat Sink Replacement: step 3, image 1 of 1
    • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
  4. PlayStation 3 Slim Heat Sink Replacement: step 4, image 1 of 1
    • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
  5. PlayStation 3 Slim Heat Sink Replacement: step 5, image 1 of 2 PlayStation 3 Slim Heat Sink Replacement: step 5, image 2 of 2
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover off the PS3.
  6. PlayStation 3 Slim Heat Sink Replacement, Power Supply: step 6, image 1 of 2 PlayStation 3 Slim Heat Sink Replacement, Power Supply: step 6, image 2 of 2
    • Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
  7. PlayStation 3 Slim Heat Sink Replacement: step 7, image 1 of 1
    • Pull the DC-Out cables straight up to lift their connector up and out of its socket on the power supply.
  8. PlayStation 3 Slim Heat Sink Replacement: step 8, image 1 of 1
    • Remove the two 7.6 mm Phillips screws securing the power supply to the lower case.
  9. PlayStation 3 Slim Heat Sink Replacement: step 9, image 1 of 1
    • Lift the power supply upward from its left edge as viewed from the front of the PS3.
  10. PlayStation 3 Slim Heat Sink Replacement: step 10, image 1 of 2 PlayStation 3 Slim Heat Sink Replacement: step 10, image 2 of 2
    • Continue to lift the left edge of the power supply until it lifts off the two metal posts shown in the second picture.
    • Remove the power supply from the PS3, minding any cables that may get caught.
  11. PlayStation 3 Slim Heat Sink Replacement, Blu-ray Disc Drive: step 11, image 1 of 2 PlayStation 3 Slim Heat Sink Replacement, Blu-ray Disc Drive: step 11, image 2 of 2
    • If present, remove the pieces of tape securing the cables to the body of the Blu-ray drive.
  12. PlayStation 3 Slim Heat Sink Replacement: step 12, image 1 of 1
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Be sure you are prying up on the movable retaining flap, not the socket itself.
  13. PlayStation 3 Slim Heat Sink Replacement: step 13, image 1 of 1
    • Pull the Blu-ray ribbon cable straight up and out of its socket.
  14. PlayStation 3 Slim Heat Sink Replacement: step 14, image 1 of 1
    • Pull the Blu-ray power cable straight up to lift its connector out of the socket on the Blu-ray drive.
  15. PlayStation 3 Slim Heat Sink Replacement: step 15, image 1 of 1
    • Remove the single 9.5 mm Phillips screw securing the Blu-ray drive to the lower case.
  16. PlayStation 3 Slim Heat Sink Replacement: step 16, image 1 of 2 PlayStation 3 Slim Heat Sink Replacement: step 16, image 2 of 2
    • Lift the Blu-ray drive slightly by its right edge to dislodge the control board from its housing.
    • Remove the Blu-ray drive from the PS3.
    • After you reinstall the Blu-ray drive, be sure the control board is firmly seated in the lower case before proceeding.
    • If replacing the Blu-ray drive with a new drive, swap the circuit board from your old drive into the new drive.
  17. PlayStation 3 Slim Heat Sink Replacement, Motherboard Assembly: step 17, image 1 of 1
    • Pull the AC-In cables upward to remove the AC inlet from the lower case.
  18. PlayStation 3 Slim Heat Sink Replacement: step 18, image 1 of 2 PlayStation 3 Slim Heat Sink Replacement: step 18, image 2 of 2
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the motherboard.
  19. PlayStation 3 Slim Heat Sink Replacement: step 19, image 1 of 1
    • Pull the control board ribbon cable up and out of its socket on the motherboard.
    • Remove the control board.
  20. PlayStation 3 Slim Heat Sink Replacement: step 20, image 1 of 1
    • Use the flat edge of a metal spudger to pop up the small access door on the bottom cover near the front of the PS3.
    • Remove the blue Phillips screw hidden under the access door.
  21. PlayStation 3 Slim Heat Sink Replacement: step 21, image 1 of 1
    • Slide the hard drive bay cover toward the right side of the lower case, then pull it away from the front edge to remove it from the PS3.
  22. PlayStation 3 Slim Heat Sink Replacement: step 22, image 1 of 1
    • Using its attached metal handle, pull the hard drive out of its bay.
  23. PlayStation 3 Slim Heat Sink Replacement: step 23, image 1 of 1
    • Remove the following five screws securing the motherboard assembly to the lower case:
    • Two silver 6 mm Phillips
    • Three black 8 mm Phillips
  24. PlayStation 3 Slim Heat Sink Replacement: step 24, image 1 of 1
    • Lift the motherboard assembly from its front edge and remove it from the lower case, minding the antenna cable still attached to the lower case.
    • Be careful not to bend the metal antenna bodies as you lift the motherboard assembly.
  25. PlayStation 3 Slim Heat Sink Replacement, Top Shield Assembly: step 25, image 1 of 1
    • Disconnect the DC-In and Blu-ray power cables from the motherboard.
    • Pull the cables straight upward to lift the connectors up and out of their sockets on the motherboard.
  26. PlayStation 3 Slim Heat Sink Replacement: step 26, image 1 of 1
    • Pull the fan cables straight up to lift the fan connector up and out of its socket on the motherboard.
  27. PlayStation 3 Slim Heat Sink Replacement: step 27, image 1 of 1
    • Remove the following nine screws holding the motherboard assembly together:
    • Four 14.8 mm shouldered Phillips
    • Five 9.5 mm Phillips
  28. PlayStation 3 Slim Heat Sink Replacement: step 28, image 1 of 1
    • Remove the two heat sink clamps from the bottom of the motherboard assembly.
  29. PlayStation 3 Slim Heat Sink Replacement: step 29, image 1 of 1
    • If necessary, gently pry the motherboard off the top shield near the heat sink and its shroud.
  30. PlayStation 3 Slim Heat Sink Replacement: step 30, image 1 of 2 PlayStation 3 Slim Heat Sink Replacement: step 30, image 2 of 2
    • Gently press the board away from the top shield assembly near the fan connector and the corner of the board near the wireless sockets.
  31. PlayStation 3 Slim Heat Sink Replacement: step 31, image 1 of 1
    • Lift the top shield assembly off the motherboard from its front edge.
    • Be careful not to damage the sockets as you rotate the top shield assembly away from the motherboard.
  32. PlayStation 3 Slim Heat Sink Replacement, Heat Sink: step 32, image 1 of 1
    • Remove the two 9.5 mm Phillips screws securing the fan to the heat sink.
  33. PlayStation 3 Slim Heat Sink Replacement: step 33, image 1 of 1
    • Remove the fan from the heat sink, minding the cables that may get caught on the fan shroud.
  34. PlayStation 3 Slim Heat Sink Replacement: step 34, image 1 of 1
    • Remove the four 9.5 mm Phillips screws securing the heat sink to the top shield.
  35. PlayStation 3 Slim Heat Sink Replacement: step 35, image 1 of 1
    • Lift the top shield off the heat sink.
    • Before installing the heat sink onto the motherboard, it is essential to apply a new layer of thermal paste. This guide will show you how to do it. Or consider this guide specific to the PS3.
47 other people completed this guide.
8 Guide Comments
Hey good day to you. Can the thermal paste be applied with this tutorial?
Anthony - Reply Share
This is a great guide, I followed it to the letter and my PS3 is now quiet as a mouse. I highly recommend you follow this, and please take your time. There’s no rush! :)
GunnZo - Reply Share
Thanks, can you extend this list by showing how thermal paste is properly applied? That is the predominate reason for my users who need to get to step 31 in your list.
Thanks
k lewis - Reply Share
Thanks for this guide
Junior Hinostroza - Reply Share
Hi, is the heatsink that makes contact with the cpu die aluminium? I think I might have repasted it with liquid metal… Thanks!
Ricardo Oprandi - Reply Share
Past 24 Hours: 8
Past 7 Days: 47
Past 30 Days: 328
All Time: 79,833
