PlayStation 3 Slim Control Board Replacement
    1. PlayStation 3 Slim Control Board Replacement, Top Cover: step 1, image 1 of 1
      • Turn the PS3 over and lay it on its backside.
      • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
      • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
      Ask FixBot
    2. PlayStation 3 Slim Control Board Replacement: step 2, image 1 of 2 PlayStation 3 Slim Control Board Replacement: step 2, image 2 of 2
      • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
      Ask FixBot
    3. PlayStation 3 Slim Control Board Replacement: step 3, image 1 of 1
      • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
      Ask FixBot
    4. PlayStation 3 Slim Control Board Replacement: step 4, image 1 of 1
      • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
      Ask FixBot
    5. PlayStation 3 Slim Control Board Replacement: step 5, image 1 of 2 PlayStation 3 Slim Control Board Replacement: step 5, image 2 of 2
      • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
      • Lift the top cover off the PS3.
      Ask FixBot
    1. PlayStation 3 Slim Control Board Replacement, Control Board: step 6, image 1 of 2 PlayStation 3 Slim Control Board Replacement, Control Board: step 6, image 2 of 2
      • Use the tip of a spudger to pry the control board out of its housing within the lower case.
      • Pull the control board ribbon cable away from its socket on the control board.
      Ask FixBot
27 other people completed this guide.
2 Guide Comments
I have a PS3 slim that won't turn on, unfortunately my Power/eject button and ribbon cable are completely removed from my PS3. Can I turn it on without the button/ribbon cable?
wrestlemaniafreak - Reply Share
I replaced the entire psu but without a standby light I have no idea if I'm close to powering it on. I suppose I could get a multimeter but I don't know what I'm testing. Any info would be appreciated.
Past 24 Hours: 15
Past 7 Days: 72
Past 30 Days: 315
All Time: 33,911
