PlayStation 3 Slim AC Inlet Replacement
    1. PlayStation 3 Slim AC Inlet Replacement, Top Cover: step 1, image 1 of 1
      • Turn the PS3 over and lay it on its backside.
      • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
      • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
      Ask FixBot
    2. PlayStation 3 Slim AC Inlet Replacement: step 2, image 1 of 2 PlayStation 3 Slim AC Inlet Replacement: step 2, image 2 of 2
      • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
      Ask FixBot
    3. PlayStation 3 Slim AC Inlet Replacement: step 3, image 1 of 1
      • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
      Ask FixBot
    4. PlayStation 3 Slim AC Inlet Replacement: step 4, image 1 of 1
      • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
      Ask FixBot
    5. PlayStation 3 Slim AC Inlet Replacement: step 5, image 1 of 2 PlayStation 3 Slim AC Inlet Replacement: step 5, image 2 of 2
      • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
      • Lift the top cover off the PS3.
      Ask FixBot
    1. PlayStation 3 Slim AC Inlet Replacement, Power Supply: step 6, image 1 of 2 PlayStation 3 Slim AC Inlet Replacement, Power Supply: step 6, image 2 of 2
      • Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
      Ask FixBot
    2. PlayStation 3 Slim AC Inlet Replacement: step 7, image 1 of 1
      • Pull the DC-Out cables straight up to lift their connector up and out of its socket on the power supply.
      Ask FixBot
    3. PlayStation 3 Slim AC Inlet Replacement: step 8, image 1 of 1
      • Remove the two 7.6 mm Phillips screws securing the power supply to the lower case.
      Ask FixBot
    4. PlayStation 3 Slim AC Inlet Replacement: step 9, image 1 of 1
      • Lift the power supply upward from its left edge as viewed from the front of the PS3.
      Ask FixBot
    5. PlayStation 3 Slim AC Inlet Replacement: step 10, image 1 of 2 PlayStation 3 Slim AC Inlet Replacement: step 10, image 2 of 2
      • Continue to lift the left edge of the power supply until it lifts off the two metal posts shown in the second picture.
      • Remove the power supply from the PS3, minding any cables that may get caught.
      Ask FixBot
    1. PlayStation 3 Slim AC Inlet Replacement, AC Inlet: step 11, image 1 of 2 PlayStation 3 Slim AC Inlet Replacement, AC Inlet: step 11, image 2 of 2
      • Lift the AC inlet cables straight upward to remove the AC inlet from the lower case.
      Ask FixBot
36 other people completed this guide.
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 56
Past 30 Days: 193
All Time: 30,059
