PlayStation 3 Power Supply Replacement
    1. PlayStation 3 Power Supply Replacement, Smart Plate: step 1, image 1 of 2 PlayStation 3 Power Supply Replacement, Smart Plate: step 1, image 2 of 2
      • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
      • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
      Ask FixBot
    2. PlayStation 3 Power Supply Replacement: step 2, image 1 of 1
      • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
      Ask FixBot
    3. PlayStation 3 Power Supply Replacement: step 3, image 1 of 3 PlayStation 3 Power Supply Replacement: step 3, image 2 of 3 PlayStation 3 Power Supply Replacement: step 3, image 3 of 3
      • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
      Ask FixBot
    4. PlayStation 3 Power Supply Replacement: step 4, image 1 of 1
      • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
      Ask FixBot
    1. PlayStation 3 Power Supply Replacement, Top Cover: step 5, image 1 of 1
      • Remove the following seven screws:
      • Six 52 mm Phillips screws
      • One 30 mm Phillips screw
      Ask FixBot
    2. PlayStation 3 Power Supply Replacement: step 6, image 1 of 1
      • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
      • Remove the top cover.
      • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
      Ask FixBot
    1. PlayStation 3 Power Supply Replacement, Memory Card Reader: step 7, image 1 of 1
      • Remove the two 9 mm Phillips screws securing the memory card reader to the chassis.
      Ask FixBot
    2. PlayStation 3 Power Supply Replacement: step 8, image 1 of 2 PlayStation 3 Power Supply Replacement: step 8, image 2 of 2
      • Lift the memory card reader out of the PS3 enough to access its cable.
      • Flip up the retaining flap on the memory card reader ribbon cable socket.
      • Be sure you are prying up on the retaining flap, not the socket itself.
      • Pull the ribbon cable out of its socket.
      • Remove the memory card reader from the PS3.
      Ask FixBot
    1. PlayStation 3 Power Supply Replacement, Power Supply: step 9, image 1 of 1
      • Pull the DC-In cables toward the front of the PS3 to disconnect them from the power supply.
      Ask FixBot
    2. PlayStation 3 Power Supply Replacement: step 10, image 1 of 1
      • Lift the AC-In cables slightly away from the rear cover for clearance to access the AC-In connector.
      Ask FixBot
    3. PlayStation 3 Power Supply Replacement: step 11, image 1 of 1
      • While depressing its locking mechanism, pull the AC-In connector out of its socket on the power supply.
      Ask FixBot
    4. PlayStation 3 Power Supply Replacement: step 12, image 1 of 1
      • Remove the five 9 mm Phillips screws securing the power supply to the chassis.
      Ask FixBot
    5. PlayStation 3 Power Supply Replacement: step 13, image 1 of 1
      • Lift the power supply upward from its front edge to disconnect it from the posts attached to the logic board.
      • Remove the power supply.
      Ask FixBot
49 other people completed this guide.
6 Guide Comments
This is for the 60gb version. As there is no card reader in the 80gb i replaced the power supply in and some of the psu screws were in a slightly different place. But a very good guide.
Craig Taylor - Reply Share
I have a Ps3 that was bought in America. The power supply is different to ours here in South Africa (Cape Town). A friend who gave me the Ps3 also had an external power supply built so that it can be used here. It's been working for years but now I have that green light thingy going. I've removed the disc that was in it and thought it may have been inserted incorrectly. Now that I have seen your tutorial I will definitely check if it's the power supply or mother board. Thank you.
patrickms - Reply Share
CAN I HAVE THE MANUAL MY RED LIGHT IS ON ALSO DIRECT ME TO A GOOD PLACE FOR REPAIRS IN ACCRA GHANA EMAIL honmante54@yahoo.com thank you
honmante54 - Reply Share
why do your consoles have this red light on why do something about it
Hi I need a good fix store in Greece for ps3 in order to replace my power supply
Manos Kallimanis - Reply Share
Past 24 Hours: 15
Past 7 Days: 86
Past 30 Days: 392
All Time: 119,843
