Up to 20% off select tools
PlayStation 3 Memory Card Reader Replacement
Views: 22K
View statistics:
Past 24 Hours:
7
Past 7 Days:
40
Past 30 Days:
188
All Time:
21,621
Comments: 36
36 comments on steps.
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 37
37 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace your PlayStation 3's memory card reader board.
    1. PlayStation 3 Memory Card Reader Replacement, Smart Plate: step 1, image 1 of 2 PlayStation 3 Memory Card Reader Replacement, Smart Plate: step 1, image 2 of 2
      • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
      • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
      Ask FixBot
    2. PlayStation 3 Memory Card Reader Replacement: step 2, image 1 of 1
      • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
      Ask FixBot
    3. PlayStation 3 Memory Card Reader Replacement: step 3, image 1 of 3 PlayStation 3 Memory Card Reader Replacement: step 3, image 2 of 3 PlayStation 3 Memory Card Reader Replacement: step 3, image 3 of 3
      • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
      Ask FixBot
    4. PlayStation 3 Memory Card Reader Replacement: step 4, image 1 of 1
      • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
      Ask FixBot
    1. PlayStation 3 Memory Card Reader Replacement, Top Cover: step 5, image 1 of 1
      • Remove the following seven screws:
      • Six 52 mm Phillips screws
      • One 30 mm Phillips screw
      Ask FixBot
    2. PlayStation 3 Memory Card Reader Replacement: step 6, image 1 of 1
      • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
      • Remove the top cover.
      • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
      Ask FixBot
    1. PlayStation 3 Memory Card Reader Replacement, Memory Card Reader: step 7, image 1 of 1
      • Remove the two 9 mm Phillips screws securing the memory card reader to the chassis.
      Ask FixBot
    2. PlayStation 3 Memory Card Reader Replacement: step 8, image 1 of 2 PlayStation 3 Memory Card Reader Replacement: step 8, image 2 of 2
      • Lift the memory card reader out of the PS3 enough to access its cable.
      • Flip up the retaining flap on the memory card reader ribbon cable socket.
      • Be sure you are prying up on the retaining flap, not the socket itself.
      • Pull the ribbon cable out of its socket.
      • Remove the memory card reader from the PS3.
      Ask FixBot
9 other people completed this guide.
Author
with
Walter Galan
712,028 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 40
Past 30 Days: 188
All Time: 21,621
