Up to 20% off select tools
PlayStation 3 Lower Case Replacement
Views: 22K
View statistics:
Past 24 Hours:
9
Past 7 Days:
47
Past 30 Days:
221
All Time:
21,879
Comments: 59
58 comments on steps, 1 guide comment.
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 28
28 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace your PlayStation 3's black plastic lower case.
    1. PlayStation 3 Lower Case Replacement, Smart Plate: step 1, image 1 of 2 PlayStation 3 Lower Case Replacement, Smart Plate: step 1, image 2 of 2
      • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
      • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
      Ask FixBot
    2. PlayStation 3 Lower Case Replacement: step 2, image 1 of 1
      • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
      Ask FixBot
    3. PlayStation 3 Lower Case Replacement: step 3, image 1 of 3 PlayStation 3 Lower Case Replacement: step 3, image 2 of 3 PlayStation 3 Lower Case Replacement: step 3, image 3 of 3
      • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
      Ask FixBot
    4. PlayStation 3 Lower Case Replacement: step 4, image 1 of 1
      • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
      Ask FixBot
    1. PlayStation 3 Lower Case Replacement, Top Cover: step 5, image 1 of 1
      • Remove the following seven screws:
      • Six 52 mm Phillips screws
      • One 30 mm Phillips screw
      Ask FixBot
    2. PlayStation 3 Lower Case Replacement: step 6, image 1 of 1
      • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
      • Remove the top cover.
      • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
      Ask FixBot
    1. PlayStation 3 Lower Case Replacement, Blu-ray Disc Drive: step 7, image 1 of 1
      • Disconnect the Blu-ray power cable from the motherboard.
      • Pull the connector straight up and out of its socket.
      Ask FixBot
    2. PlayStation 3 Lower Case Replacement: step 8, image 1 of 1
      • Lift the Blu-ray drive from the edge nearest the power supply and rotate it away from the chassis enough to access its ribbon cable.
      Ask FixBot
    3. PlayStation 3 Lower Case Replacement: step 9, image 1 of 3 PlayStation 3 Lower Case Replacement: step 9, image 2 of 3 PlayStation 3 Lower Case Replacement: step 9, image 3 of 3
      • Use your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
      • Be sure you are prying up on the retaining flap, not the socket itself.
      • Pull the ribbon cable out of its socket.
      • Remove the Blu-ray drive from the PS3.
      • If replacing the Blu-ray drive, transfer the power cable to your new drive.
      Ask FixBot
    1. PlayStation 3 Lower Case Replacement, Motherboard Assembly: step 10, image 1 of 1
      • Pull the control board ribbon cable straight up and out of its socket on the motherboard.
      Ask FixBot
    2. PlayStation 3 Lower Case Replacement: step 11, image 1 of 2 PlayStation 3 Lower Case Replacement: step 11, image 2 of 2
      • Remove the two 12 mm Phillips screws securing the control board to the lower case.
      • Remove the control board and its attached cable from the PS3.
      Ask FixBot
    3. PlayStation 3 Lower Case Replacement: step 12, image 1 of 1
      • Remove the following eight screws securing the motherboard assembly to the lower case:
      • Seven 12 mm Phillips screws (ph2)
      Ask FixBot
    4. PlayStation 3 Lower Case Replacement: step 13, image 1 of 1
      • Remove the control board bracket.
      Ask FixBot
    5. PlayStation 3 Lower Case Replacement: step 14, image 1 of 2 PlayStation 3 Lower Case Replacement: step 14, image 2 of 2
      • Use the flat end of a spudger to pry the hard drive bay cover away from the lower case.
      • Remove the hard drive bay cover.
      Ask FixBot
    6. PlayStation 3 Lower Case Replacement: step 15, image 1 of 1
      • Lift the motherboard assembly out of the lower case.
      Ask FixBot
    1. PlayStation 3 Lower Case Replacement, Lower Case: step 16, image 1 of 1
      • Lower case remains.
      Ask FixBot
15 other people completed this guide.
Author
with
Walter Galan
712,031 Reputation
1,203 Guides authored
1 Guide Comment
let op dat het zelfde model is anders past hij niet
j-w van den berg - Reply Share
Past 24 Hours: 9
Past 7 Days: 47
Past 30 Days: 221
All Time: 21,879
