Up to 20% off select tools
PlayStation 3 Hard Drive Replacement
Views: 266K
View statistics:
Past 24 Hours:
47
Past 7 Days:
331
Past 30 Days:
1,204
All Time:
265,657
Comments: 23
4 comments on steps, 19 guide comments.
Go to guide comments
Completed: 166
166 people have marked this guide "completed." Will you be next?
Favorites: 129
129 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Fix Kits
These kits contain all the parts and tools needed to complete this guide.
Parts
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Use this guide to replace your PlayStation 3's hard drive.
    1. PlayStation 3 Hard Drive Replacement, Hard Drive Backup: step 1, image 1 of 2 PlayStation 3 Hard Drive Replacement, Hard Drive Backup: step 1, image 2 of 2
      • If you need to backup the data on your current hard drive, follow the instructions in this step. Otherwise, continue to the next step.
      • On a Windows/OS X/Linux machine, format an external USB hard drive (with enough space available to backup your current hard content) into the FAT32 file system.
      • Make sure it's formatted FAT32. The Playstation 3 backup utility will not recognize any other file system.
      • Connect your formatted hard drive to the Playstation 3 through a USB port and power the console up.
      • Navigate the XMB to the 'Settings' menu and select 'System Settings'
      • Select the 'Backup Utility' function to create a backup of your data - this can take up to 2 hours if you have a lot of data on the PS3.
      Ask FixBot
    1. PlayStation 3 Hard Drive Replacement, Hard Drive: step 2, image 1 of 2 PlayStation 3 Hard Drive Replacement, Hard Drive: step 2, image 2 of 2
      • Use the flat end of a spudger to pry the hard drive door away from the lower case.
      • Remove the hard drive door from the PS3.
      Ask FixBot
    2. PlayStation 3 Hard Drive Replacement: step 3, image 1 of 1
      • Remove the blue 8 mm Phillips screw securing the hard drive cage to the chassis.
      Ask FixBot
    3. PlayStation 3 Hard Drive Replacement: step 4, image 1 of 3 PlayStation 3 Hard Drive Replacement: step 4, image 2 of 3 PlayStation 3 Hard Drive Replacement: step 4, image 3 of 3
      • Grab the hard drive pull tab and pull the hard drive toward the front face of the PS3.
      • Pull the hard drive assembly out of the PS3.
      Ask FixBot
    1. PlayStation 3 Hard Drive Replacement, Hard Drive: step 5, image 1 of 2 PlayStation 3 Hard Drive Replacement, Hard Drive: step 5, image 2 of 2
      Tool used on this step:
      Screw Extracting Pliers
      $23.95
      Buy
      • Remove the four 4.3 mm Phillips screws securing the hard drive cage to the hard drive.
      • These 4 screws can sometimes be very difficult to remove. If you strip the heads our Screw Extracting Pliers remove the damaged screws nicely.
      Ask FixBot
    2. PlayStation 3 Hard Drive Replacement: step 6, image 1 of 1
      • Remove the hard drive from its steel cage.
      • If you're installing a new hard drive into your PS3, use this guide to restore the data you backed up.
      Ask FixBot
166 other people completed this guide.
Author
with
Walter Galan
712,031 Reputation
1,203 Guides authored
19 Guide Comments
Hi there!
Thank you for this (and all the other) guide!
My Hard Drive Slot looks a little bit different.
You have to spudge away the door from the left side and after removing the Blue Screw you can easily pull out the harddrive and you don't have to slide the tray to the side and out afterwards.
Maybe worth a note that there are several versions around..
Jay Ho - Reply Share
Nice explenatory guide!
Dirk Ronsmans - Reply Share
My playstation3 fell over" lost all my icons on screen. I took it in to see what's wrong, they say I need to replace hard drive. Were can I buy a hard drive and how much does it cost? Can I do it myself? Please give me some answers or tips
alexhuman49 - Reply Share
if you can’t figure that out you should stop gaming…
Azhrei2000 - Reply Share
You can find a new hard drive on Amazon. Data's gone, though.
TheTank20 - Reply Share
Past 24 Hours: 47
Past 7 Days: 331
Past 30 Days: 1,204
All Time: 265,657
