PlayStation 3 Blu-Ray Laser Replacement
    1. PlayStation 3 Blu-Ray Laser Replacement, Smart Plate: step 1, image 1 of 2 PlayStation 3 Blu-Ray Laser Replacement, Smart Plate: step 1, image 2 of 2
      • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
      • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
      Ask FixBot
    2. PlayStation 3 Blu-Ray Laser Replacement: step 2, image 1 of 1
      • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
      Ask FixBot
    3. PlayStation 3 Blu-Ray Laser Replacement: step 3, image 1 of 3 PlayStation 3 Blu-Ray Laser Replacement: step 3, image 2 of 3 PlayStation 3 Blu-Ray Laser Replacement: step 3, image 3 of 3
      • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
      Ask FixBot
    4. PlayStation 3 Blu-Ray Laser Replacement: step 4, image 1 of 1
      • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
      Ask FixBot
    1. PlayStation 3 Blu-Ray Laser Replacement, Top Cover: step 5, image 1 of 1
      • Remove the following seven screws:
      • Six 52 mm Phillips screws
      • One 30 mm Phillips screw
      Ask FixBot
    2. PlayStation 3 Blu-Ray Laser Replacement: step 6, image 1 of 1
      • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
      • Remove the top cover.
      • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
      Ask FixBot
    1. PlayStation 3 Blu-Ray Laser Replacement, Blu-ray Disc Drive: step 7, image 1 of 1
      • Disconnect the Blu-ray power cable from the motherboard.
      • Pull the connector straight up and out of its socket.
      Ask FixBot
    2. PlayStation 3 Blu-Ray Laser Replacement: step 8, image 1 of 1
      • Lift the Blu-ray drive from the edge nearest the power supply and rotate it away from the chassis enough to access its ribbon cable.
      Ask FixBot
    3. PlayStation 3 Blu-Ray Laser Replacement: step 9, image 1 of 3 PlayStation 3 Blu-Ray Laser Replacement: step 9, image 2 of 3 PlayStation 3 Blu-Ray Laser Replacement: step 9, image 3 of 3
      • Use your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
      • Be sure you are prying up on the retaining flap, not the socket itself.
      • Pull the ribbon cable out of its socket.
      • Remove the Blu-ray drive from the PS3.
      • If replacing the Blu-ray drive, transfer the power cable to your new drive.
      Ask FixBot
    1. PlayStation 3 Blu-Ray Laser Replacement, Blu-Ray Laser: step 10, image 1 of 1
      • A2 ribbon cable was removed in Step 9 of the previous guide. Now remove ribbon cables A3, A4, A5 and A6 by using your fingernail to flip open the ribbon flaps.
      • With a Ph#00 screwdriver remove screws 9, 10, 11, 12 and 13.
      • Note that screws 11 & 13 are fastening a stabiliser on some models. These are pictured in the third photo in step 9, and you will need to recall their position for reassembly.
      Ask FixBot
    2. PlayStation 3 Blu-Ray Laser Replacement: step 11, image 1 of 1
      • With extreme caution move the BluRay control board in a flipping motion by moving the left side of the controller upwards levering towards the right. Keep the right side of the controller close to the BluRay drive as the red and black A7 cable is delicate.
      • Remove cable A7 which is the cable that links the PS3s disc drive eject detector to the control board.
      Ask FixBot
    3. PlayStation 3 Blu-Ray Laser Replacement: step 12, image 1 of 1
      • Remove screws 14 and 15.
      • Part C is a stabilizer and grounding contact to help absorb movement while the Blu-ray drive is in use. This may be located in a different area of your drive as decided by the manufacturer. There may also be additional ones. Make sure when reassembling to put this stabiliser back in the same place as it is originally found even if it is not found in exactly the same location as this article. Failure to do so could result in disc scratching.
      • Remove the silver coloured drive cover.
      Ask FixBot
    4. PlayStation 3 Blu-Ray Laser Replacement: step 13, image 1 of 1
      • Remove screws 16, 17, 18, 19 and 20.
      • Remove magnetic spindle D.
      • Remove top of drive being careful again not to damage the red and black cable.
      Ask FixBot
    5. PlayStation 3 Blu-Ray Laser Replacement: step 14, image 1 of 1
      • Remove screws 21 and 22 and the brackets they hold in place.
      • Now remove bar E.
      • Unclip ribbon F.
      • Remove and replace Laser Assembly G with new Laser Assembly.
      • Follow this guide in reverse to reassemble.
      Ask FixBot
      • The KES-400AAA laser is known to work with the following models: CECHE03, CECHA03, CECHC03, CECHG03, CECHB0 and CECHC03 but more variants accept the KES-400AAA laser assembly. Please contact the seller for more information. Generally older models with 4 usb ports accept the KES-400AAA while the 2 usb models use the KES-410CA laser assembly.
      Ask FixBot
79 other people completed this guide.
KingArkon
2,834 Reputation
1 Guide authored
29 Guide Comments
Perhaps this guide can integrate the procedure for removing a stuck disc? Many YLOD units die with a disc in the drive and some repair service providers charge extra to remove it. What's worse, sometimes it is not your disc! I was going to send it to Sony for my repair except that the disc inside is rented and needs to be extracted right away. The repair providers who charge extra implied to me that they charge extra because the drive needs a disc reinserted if it is going to work again when booted up in a working PS3 (something about rails that would fall without a disc holding them up). I believe that they throw in a blank CD/DVD or one of those clear plastic separator discs that come in recordable disc cake-boxes on the top and bottom of the stack.
Julian Turner - Reply Share
If you do these steps you will get to the disk and remove it easily
PS2 Dealer - Reply Share
This tutorial is brilliant and saved my PS3. Thank you.
One comment or question really: Between steps 9 and 10 a heat shield magically appears. In Step 9 when you see the drive being taken off, there's no apparent heat shield.
But in Step 10 we see the heat shield. On my unit, there doesn't appear to be one. So this was - and is - a little confusing. I thought somehow I'd lost the part. (Though in the space I was working, there's just nowhere it could have gone.) Is this a problem to not have this? It's hard to tell from your pics whether the original had a shield or not or if these were two different units.
Thanks
Scott Germaise - Reply Share
You are correct, the units in steps 9 and 10 are different. Steps 1-9 are part of an original iFixit tear-down, steps 10-15 are my user-created guide which iFixit staff have merged with their own.
There may be some variation between units, if your original disc drive didn't have a heat shield then I wouldn't worry. It doesn't appear that the unit in steps 1-9 from iFixit had one either. Thanks for the feedback, I'm glad the guide helped you fix your issue.
KingArkon - Reply Share
It is not recommended to replace just the laser unit. It is better to replace the drive chassis (metal part, including the rail and disc spindle motor) as an assembly because the height of the rails are calibrated in factory. Unscrewing the rail screws will change the alignment and you can't calibrate it.
Tom Chai - Reply Share
Past 24 Hours: 29
Past 7 Days: 145
Past 30 Days: 656
All Time: 254,415
