Up to 20% off select tools
PlayStation 3 AC Inlet Replacement
Views: 39K
View statistics:
Past 24 Hours:
7
Past 7 Days:
42
Past 30 Days:
199
All Time:
39,034
Comments: 64
63 comments on steps, 1 guide comment.
Go to guide comments
Completed: 25
25 people have marked this guide "completed." Will you be next?
Favorites: 41
41 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace your PlayStation 3's AC inlet.
    1. PlayStation 3 AC Inlet Replacement, Smart Plate: step 1, image 1 of 2 PlayStation 3 AC Inlet Replacement, Smart Plate: step 1, image 2 of 2
      • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
      • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
      Ask FixBot
    2. PlayStation 3 AC Inlet Replacement: step 2, image 1 of 1
      • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
      Ask FixBot
    3. PlayStation 3 AC Inlet Replacement: step 3, image 1 of 3 PlayStation 3 AC Inlet Replacement: step 3, image 2 of 3 PlayStation 3 AC Inlet Replacement: step 3, image 3 of 3
      • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
      Ask FixBot
    4. PlayStation 3 AC Inlet Replacement: step 4, image 1 of 1
      • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
      Ask FixBot
    1. PlayStation 3 AC Inlet Replacement, Top Cover: step 5, image 1 of 1
      • Remove the following seven screws:
      • Six 52 mm Phillips screws
      • One 30 mm Phillips screw
      Ask FixBot
    2. PlayStation 3 AC Inlet Replacement: step 6, image 1 of 1
      • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
      • Remove the top cover.
      • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
      Ask FixBot
    1. PlayStation 3 AC Inlet Replacement, Blu-ray Disc Drive: step 7, image 1 of 1
      • Disconnect the Blu-ray power cable from the motherboard.
      • Pull the connector straight up and out of its socket.
      Ask FixBot
    2. PlayStation 3 AC Inlet Replacement: step 8, image 1 of 1
      • Lift the Blu-ray drive from the edge nearest the power supply and rotate it away from the chassis enough to access its ribbon cable.
      Ask FixBot
    3. PlayStation 3 AC Inlet Replacement: step 9, image 1 of 3 PlayStation 3 AC Inlet Replacement: step 9, image 2 of 3 PlayStation 3 AC Inlet Replacement: step 9, image 3 of 3
      • Use your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
      • Be sure you are prying up on the retaining flap, not the socket itself.
      • Pull the ribbon cable out of its socket.
      • Remove the Blu-ray drive from the PS3.
      • If replacing the Blu-ray drive, transfer the power cable to your new drive.
      Ask FixBot
    1. PlayStation 3 AC Inlet Replacement, Motherboard Assembly: step 10, image 1 of 1
      • Pull the control board ribbon cable straight up and out of its socket on the motherboard.
      Ask FixBot
    2. PlayStation 3 AC Inlet Replacement: step 11, image 1 of 2 PlayStation 3 AC Inlet Replacement: step 11, image 2 of 2
      • Remove the two 12 mm Phillips screws securing the control board to the lower case.
      • Remove the control board and its attached cable from the PS3.
      Ask FixBot
    3. PlayStation 3 AC Inlet Replacement: step 12, image 1 of 1
      • Remove the following eight screws securing the motherboard assembly to the lower case:
      • Seven 12 mm Phillips screws (ph2)
      Ask FixBot
    4. PlayStation 3 AC Inlet Replacement: step 13, image 1 of 1
      • Remove the control board bracket.
      Ask FixBot
    5. PlayStation 3 AC Inlet Replacement: step 14, image 1 of 2 PlayStation 3 AC Inlet Replacement: step 14, image 2 of 2
      • Use the flat end of a spudger to pry the hard drive bay cover away from the lower case.
      • Remove the hard drive bay cover.
      Ask FixBot
    6. PlayStation 3 AC Inlet Replacement: step 15, image 1 of 1
      • Lift the motherboard assembly out of the lower case.
      Ask FixBot
    1. PlayStation 3 AC Inlet Replacement, AC Inlet: step 16, image 1 of 1
      • Remove the 7.7 mm Phillips screw securing the ground strap to the chassis.
      Ask FixBot
    2. PlayStation 3 AC Inlet Replacement: step 17, image 1 of 2 PlayStation 3 AC Inlet Replacement: step 17, image 2 of 2
      • Pull the AC-In cables slightly away from the rear cover for clearance to access the AC-In connector.
      • While depressing its locking mechanism, pull the AC-In connector out of its socket on the power supply.
      Ask FixBot
    3. PlayStation 3 AC Inlet Replacement: step 18, image 1 of 1
      • Pull the AC inlet out from the bottom of the rear cover, minding any of its cables that may get caught.
      Ask FixBot
25 other people completed this guide.
Author
with
Walter Galan
712,031 Reputation
1,203 Guides authored
1 Guide Comment
Chupa chups ahhhhh guide
Harold - Reply Share
Past 24 Hours: 7
Past 7 Days: 42
Past 30 Days: 199
All Time: 39,034
