PlayStation 2 Slimline Optical Drive Replacement
Views: 41K
View statistics:
Past 24 Hours:
12
Past 7 Days:
114
Past 30 Days:
662
All Time:
41,203
Comments: 10
2 comments on steps, 8 guide comments.
Go to guide comments
Completed: 33
33 people have marked this guide "completed." Will you be next?
Favorites: 18
18 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
    1. PlayStation 2 Slimline Optical Drive Replacement, Outer Shell: step 1, image 1 of 1
      • Disconnect all cables from the console and flip the unit over to reveal its base.
      Ask FixBot
    2. PlayStation 2 Slimline Optical Drive Replacement: step 2, image 1 of 3 PlayStation 2 Slimline Optical Drive Replacement: step 2, image 2 of 3 PlayStation 2 Slimline Optical Drive Replacement: step 2, image 3 of 3
      • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
      • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
      Ask FixBot
    3. PlayStation 2 Slimline Optical Drive Replacement: step 3, image 1 of 3 PlayStation 2 Slimline Optical Drive Replacement: step 3, image 2 of 3 PlayStation 2 Slimline Optical Drive Replacement: step 3, image 3 of 3
      • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
      Ask FixBot
    4. PlayStation 2 Slimline Optical Drive Replacement: step 4, image 1 of 3 PlayStation 2 Slimline Optical Drive Replacement: step 4, image 2 of 3 PlayStation 2 Slimline Optical Drive Replacement: step 4, image 3 of 3
      • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
      • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
      Ask FixBot
    1. PlayStation 2 Slimline Optical Drive Replacement, Optical Drive: step 5, image 1 of 2 PlayStation 2 Slimline Optical Drive Replacement, Optical Drive: step 5, image 2 of 2
      • Locate the optical drive which occupies most of the space on the right side of the unit. It can be identified by the four screws with wide-diameter heads fastening the optical drive to the motherboard.
      Ask FixBot
    2. PlayStation 2 Slimline Optical Drive Replacement: step 6, image 1 of 2 PlayStation 2 Slimline Optical Drive Replacement: step 6, image 2 of 2
      • Remove the four 4.0 mm screws using a #1 Phillips screwdriver.
      Ask FixBot
    3. PlayStation 2 Slimline Optical Drive Replacement: step 7, image 1 of 1
      • Locate the three ribbon cables connecting the optical drive to the motherboard.
      Ask FixBot
    4. PlayStation 2 Slimline Optical Drive Replacement: step 8, image 1 of 3 PlayStation 2 Slimline Optical Drive Replacement: step 8, image 2 of 3 PlayStation 2 Slimline Optical Drive Replacement: step 8, image 3 of 3
      Tool used on this step:
      Buy
      • Gently detach the ribbon cables from the motherboard using a pair of tweezers.
      • Note: The ribbon cable in the center must be unlocked by lifting up the black tab. Remember to push the tab down upon re-installation to secure the cable.
      • Caution: Always remove ribbon cables by the plastic handles located on each end. Gripping a ribbon cable anywhere but the provided handles can damage the cable and render the component useless.
      Ask FixBot
    5. PlayStation 2 Slimline Optical Drive Replacement: step 9, image 1 of 3 PlayStation 2 Slimline Optical Drive Replacement: step 9, image 2 of 3 PlayStation 2 Slimline Optical Drive Replacement: step 9, image 3 of 3
      • Remove any tape fastening the cables to the motherboard and gently lift and remove the optical drive.
      Ask FixBot
33 other people completed this guide.
Thomas Sullivan
4,876 Reputation
6 Guides authored
8 Guide Comments
انا أريد للغة عربية
Muammar lmgaroush - Reply Share
you also must disconnect the ribbon cable from the laser assembly by flipping back the little brown lever and removing the cable. This frees the assembly from the rest of the console. To actually replace the drive, you need to move the lens away from the disc hub by gently turning the worm gear. Flip the new assembly over and connect the brown ribbon that is glued to the metal shield. DO NOT REMOVE THE GLUED RIBBON UNLESS YOU INTEND TO REPLACE IT. After that one is connected, you can slowly flip the assembly and rest is in place. Connect the other ribbons to their respective connectors. Return all the screws to their positions and tighten so they are firm. Don’t go overboard screwing them back in.
Rusty Shackleford - Reply Share
Hello is the optical drive from my ps2 70004 compatible in my ps2 slim 75001?
Jorick Earl Bastian - Reply Share
I don't see any reason why it shouldn't be.
LOLMAN 9538 (LOLMAN9538) - Reply Share
This is a great instructional aside from one thing, if you don’t not have the tape/glue for the ribbon cable that goes under the assembly, do not remove that ribbon cable from the shell. just disconnect it from the assembly, and put it in the new assembly. I wish I had read the comments before I did this myself. Please add this to the notes for the instructional. Now one of my games are ruined, and I have to buy a new one.
Noah L - Reply Share
Past 24 Hours: 12
Past 7 Days: 114
Past 30 Days: 662
All Time: 41,203
