PlayStation 2 Slimline Motherboard Replacement
    1. PlayStation 2 Slimline Motherboard Replacement, Outer Shell: step 1, image 1 of 1
      • Disconnect all cables from the console and flip the unit over to reveal its base.
      Ask FixBot
    2. PlayStation 2 Slimline Motherboard Replacement: step 2, image 1 of 3 PlayStation 2 Slimline Motherboard Replacement: step 2, image 2 of 3 PlayStation 2 Slimline Motherboard Replacement: step 2, image 3 of 3
      • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
      • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
      Ask FixBot
    3. PlayStation 2 Slimline Motherboard Replacement: step 3, image 1 of 3 PlayStation 2 Slimline Motherboard Replacement: step 3, image 2 of 3 PlayStation 2 Slimline Motherboard Replacement: step 3, image 3 of 3
      • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
      Ask FixBot
    4. PlayStation 2 Slimline Motherboard Replacement: step 4, image 1 of 3 PlayStation 2 Slimline Motherboard Replacement: step 4, image 2 of 3 PlayStation 2 Slimline Motherboard Replacement: step 4, image 3 of 3
      • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
      • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
      Ask FixBot
    1. PlayStation 2 Slimline Motherboard Replacement, Fan: step 5, image 1 of 2 PlayStation 2 Slimline Motherboard Replacement, Fan: step 5, image 2 of 2
      • Locate the fan at the front, left section of the unit.
      Ask FixBot
    2. PlayStation 2 Slimline Motherboard Replacement: step 6, image 1 of 2 PlayStation 2 Slimline Motherboard Replacement: step 6, image 2 of 2
      • Peel off the sticker holding the power cords to the unit.
      Ask FixBot
    3. PlayStation 2 Slimline Motherboard Replacement: step 7, image 1 of 2 PlayStation 2 Slimline Motherboard Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Lift the connector from the motherboard with a pair of tweezers using a firm, upward force.
      Ask FixBot
    4. PlayStation 2 Slimline Motherboard Replacement: step 8, image 1 of 3 PlayStation 2 Slimline Motherboard Replacement: step 8, image 2 of 3 PlayStation 2 Slimline Motherboard Replacement: step 8, image 3 of 3
      • Remove all three 1.6 mm screws fastening the fan to the unit using a #1 Phillips screwdriver.
      • Gently lift and remove the fan from its compartment.
      Ask FixBot
    1. PlayStation 2 Slimline Motherboard Replacement, Clock Battery: step 9, image 1 of 1
      • Locate the clock battery at the front, right section of the unit. The battery has a circular shape with red (+) and black (-) wires connecting to the motherboard.
      Ask FixBot
    2. PlayStation 2 Slimline Motherboard Replacement: step 10, image 1 of 2 PlayStation 2 Slimline Motherboard Replacement: step 10, image 2 of 2
      Buy
      Ask FixBot
    3. PlayStation 2 Slimline Motherboard Replacement: step 11, image 1 of 2 PlayStation 2 Slimline Motherboard Replacement: step 11, image 2 of 2
      • Gently lift and remove the battery from its compartment using a spudger.
      Ask FixBot
    1. PlayStation 2 Slimline Motherboard Replacement, IR Sensor: step 12, image 1 of 1
      • Locate the IR sensor at the front, right corner of the unit.
      Ask FixBot
    2. PlayStation 2 Slimline Motherboard Replacement: step 13, image 1 of 1
      • Gently detach the ribbon cable connecting the IR sensor to the motherboard.
      • Caution: Always remove ribbon cables by the plastic handles located on either end. Gripping a ribbon cable anywhere but the provided handles can damage the cable and render the component useless.
      Ask FixBot
    3. PlayStation 2 Slimline Motherboard Replacement: step 14, image 1 of 1
      • Gently lift and remove the IR Sensor from its designated slot.
      Ask FixBot
    1. PlayStation 2 Slimline Motherboard Replacement, Optical Drive: step 15, image 1 of 2 PlayStation 2 Slimline Motherboard Replacement, Optical Drive: step 15, image 2 of 2
      • Locate the optical drive which occupies most of the space on the right side of the unit. It can be identified by the four screws with wide-diameter heads fastening the optical drive to the motherboard.
      Ask FixBot
    2. PlayStation 2 Slimline Motherboard Replacement: step 16, image 1 of 2 PlayStation 2 Slimline Motherboard Replacement: step 16, image 2 of 2
      • Remove the four 4.0 mm screws using a #1 Phillips screwdriver.
      Ask FixBot
    3. PlayStation 2 Slimline Motherboard Replacement: step 17, image 1 of 1
      • Locate the three ribbon cables connecting the optical drive to the motherboard.
      Ask FixBot
    4. PlayStation 2 Slimline Motherboard Replacement: step 18, image 1 of 3 PlayStation 2 Slimline Motherboard Replacement: step 18, image 2 of 3 PlayStation 2 Slimline Motherboard Replacement: step 18, image 3 of 3
      Buy
      • Gently detach the ribbon cables from the motherboard using a pair of tweezers.
      • Note: The ribbon cable in the center must be unlocked by lifting up the black tab. Remember to push the tab down upon re-installation to secure the cable.
      • Caution: Always remove ribbon cables by the plastic handles located on each end. Gripping a ribbon cable anywhere but the provided handles can damage the cable and render the component useless.
      Ask FixBot
    5. PlayStation 2 Slimline Motherboard Replacement: step 19, image 1 of 3 PlayStation 2 Slimline Motherboard Replacement: step 19, image 2 of 3 PlayStation 2 Slimline Motherboard Replacement: step 19, image 3 of 3
      • Remove any tape fastening the cables to the motherboard and gently lift and remove the optical drive.
      Ask FixBot
    1. PlayStation 2 Slimline Motherboard Replacement, Motherboard: step 20, image 1 of 1
      • Remove the 2.4 mm screw located in between the controller ports using a #1 Phillips screwdriver.
      Ask FixBot
    2. PlayStation 2 Slimline Motherboard Replacement: step 21, image 1 of 3 PlayStation 2 Slimline Motherboard Replacement: step 21, image 2 of 3 PlayStation 2 Slimline Motherboard Replacement: step 21, image 3 of 3
      • Gently lift and remove the motherboard and chassis from the outer shell.
      Ask FixBot
    3. PlayStation 2 Slimline Motherboard Replacement: step 22, image 1 of 3 PlayStation 2 Slimline Motherboard Replacement: step 22, image 2 of 3 PlayStation 2 Slimline Motherboard Replacement: step 22, image 3 of 3
      • There are a total of five 1.6 mm screws which mount the metal chassis to the motherboard.
      • Remove the screw on top and the four screws on the bottom with a #1 Phillips screwdriver.
      Ask FixBot
    4. PlayStation 2 Slimline Motherboard Replacement: step 23, image 1 of 3 PlayStation 2 Slimline Motherboard Replacement: step 23, image 2 of 3 PlayStation 2 Slimline Motherboard Replacement: step 23, image 3 of 3
      • Gently separate the two metal plates from the motherboard.
      Ask FixBot
38 other people completed this guide.
Thomas Sullivan
4,867 Reputation
6 Guides authored
2 Guide Comments
نرجو اضافة اللغة العربية
Muammar lmgaroush - Reply Share
Mi placa no tiene corriente, seguro tiene un corto quien me ayuda a solucionar, es la 77001, ya tiene botón y flex nuevo y no me da luz Led
gasper6913 - Reply Share
Past 24 Hours: 16
Past 7 Days: 85
Past 30 Days: 356
All Time: 34,113
