PlayStation 2 Slimline IR Sensor Replacement
Views: 11K
View statistics:
Past 24 Hours:
4
Past 7 Days:
32
Past 30 Days:
158
All Time:
10,507
Comments: 1
1 comment on steps.
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide will show you how to locate and replace the Infrared Sensor in the Playstation 2 Slimline. The IR sensor reads wireless signals so PS2 controllers and remotes function as if they were plugged into the unit.
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
    1. PlayStation 2 Slimline IR Sensor Replacement, Outer Shell: step 1, image 1 of 1
      • Disconnect all cables from the console and flip the unit over to reveal its base.
      Ask FixBot
    2. PlayStation 2 Slimline IR Sensor Replacement: step 2, image 1 of 3 PlayStation 2 Slimline IR Sensor Replacement: step 2, image 2 of 3 PlayStation 2 Slimline IR Sensor Replacement: step 2, image 3 of 3
      • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
      • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
      Ask FixBot
    3. PlayStation 2 Slimline IR Sensor Replacement: step 3, image 1 of 3 PlayStation 2 Slimline IR Sensor Replacement: step 3, image 2 of 3 PlayStation 2 Slimline IR Sensor Replacement: step 3, image 3 of 3
      • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
      Ask FixBot
    4. PlayStation 2 Slimline IR Sensor Replacement: step 4, image 1 of 3 PlayStation 2 Slimline IR Sensor Replacement: step 4, image 2 of 3 PlayStation 2 Slimline IR Sensor Replacement: step 4, image 3 of 3
      • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
      • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
      Ask FixBot
    1. PlayStation 2 Slimline IR Sensor Replacement, IR Sensor: step 5, image 1 of 1
      • Locate the IR sensor at the front, right corner of the unit.
      Ask FixBot
    2. PlayStation 2 Slimline IR Sensor Replacement: step 6, image 1 of 1
      • Gently detach the ribbon cable connecting the IR sensor to the motherboard.
      • Caution: Always remove ribbon cables by the plastic handles located on either end. Gripping a ribbon cable anywhere but the provided handles can damage the cable and render the component useless.
      Ask FixBot
    3. PlayStation 2 Slimline IR Sensor Replacement: step 7, image 1 of 1
      • Gently lift and remove the IR Sensor from its designated slot.
      Ask FixBot
15 other people completed this guide.
Thomas Sullivan
4,876 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 158
All Time: 10,507
