PlayStation 2 Slimline Fan Replacement
Views: 13K
View statistics:
Past 24 Hours:
7
Past 7 Days:
48
Past 30 Days:
226
All Time:
12,999
Comments: 1
1 guide comment.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide will show you how to locate and replace the fan in the PlayStation 2 Slimline.
Tools
    1. PlayStation 2 Slimline Fan Replacement, Outer Shell: step 1, image 1 of 1
      • Disconnect all cables from the console and flip the unit over to reveal its base.
      Ask FixBot
    2. PlayStation 2 Slimline Fan Replacement: step 2, image 1 of 3 PlayStation 2 Slimline Fan Replacement: step 2, image 2 of 3 PlayStation 2 Slimline Fan Replacement: step 2, image 3 of 3
      • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
      • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
      Ask FixBot
    3. PlayStation 2 Slimline Fan Replacement: step 3, image 1 of 3 PlayStation 2 Slimline Fan Replacement: step 3, image 2 of 3 PlayStation 2 Slimline Fan Replacement: step 3, image 3 of 3
      • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
      Ask FixBot
    4. PlayStation 2 Slimline Fan Replacement: step 4, image 1 of 3 PlayStation 2 Slimline Fan Replacement: step 4, image 2 of 3 PlayStation 2 Slimline Fan Replacement: step 4, image 3 of 3
      • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
      • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
      Ask FixBot
    1. PlayStation 2 Slimline Fan Replacement, Fan: step 5, image 1 of 2 PlayStation 2 Slimline Fan Replacement, Fan: step 5, image 2 of 2
      • Locate the fan at the front, left section of the unit.
      Ask FixBot
    2. PlayStation 2 Slimline Fan Replacement: step 6, image 1 of 2 PlayStation 2 Slimline Fan Replacement: step 6, image 2 of 2
      • Peel off the sticker holding the power cords to the unit.
      Ask FixBot
    3. PlayStation 2 Slimline Fan Replacement: step 7, image 1 of 2 PlayStation 2 Slimline Fan Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Lift the connector from the motherboard with a pair of tweezers using a firm, upward force.
      Ask FixBot
    4. PlayStation 2 Slimline Fan Replacement: step 8, image 1 of 3 PlayStation 2 Slimline Fan Replacement: step 8, image 2 of 3 PlayStation 2 Slimline Fan Replacement: step 8, image 3 of 3
      • Remove all three 1.6 mm screws fastening the fan to the unit using a #1 Phillips screwdriver.
      • Gently lift and remove the fan from its compartment.
      Ask FixBot
11 other people completed this guide.
Thomas Sullivan
4,876 Reputation
6 Guides authored
1 Guide Comment
Una disculpa ayuda es que lo arranque por accidente podría darme una ayuda
A
Diegoraul Martinez Martinez - Reply Share
Past 24 Hours: 7
Past 7 Days: 48
Past 30 Days: 226
All Time: 12,999
