PlayStation 2 Slimline CMOS Battery Replacement
  1. PlayStation 2 Slimline CMOS Battery Replacement, CMOS Battery: step 1, image 1 of 2 PlayStation 2 Slimline CMOS Battery Replacement, CMOS Battery: step 1, image 2 of 2
    • Remove all five screws on the downside of the PS2 Slimline
    • Underneath the "Do not remove" sticker, there will be one last screw
    Ask FixBot
  2. PlayStation 2 Slimline CMOS Battery Replacement, Remove the plate: step 2, image 1 of 2 PlayStation 2 Slimline CMOS Battery Replacement, Remove the plate: step 2, image 2 of 2
    • Using a metal spudger, carefully pry open the chassis
    • Although a metal spudger is used in the tutorial, it is recommended to use plastic spudgers with most electronics as metal on metal can short circuts
    Ask FixBot
  3. PlayStation 2 Slimline CMOS Battery Replacement, Remove the Battery: step 3, image 1 of 3 PlayStation 2 Slimline CMOS Battery Replacement, Remove the Battery: step 3, image 2 of 3 PlayStation 2 Slimline CMOS Battery Replacement, Remove the Battery: step 3, image 3 of 3
    • Locate the battery on the motherboard. The battery will be a CR2032 Button Cell Battery
    • Carefully use a metal spudger to pull the battery out of the metal housing
    • Once the battery is fully removed, remove the connector upwards from the motherboard
    • The connector does not have any clips and can be easily removed and pushed back in with reassembly/disassembly
    Ask FixBot
7 other people completed this guide.
tlroesner
1,891 Reputation
4 Guides authored
3 Guide Comments
why would i need to do this?
Dimitrios Frantzis - Reply Share
To prior poster, you will not be able to effectively play certain types of games once the server is shut off by Sony.
Joe W. - Reply Share
What do I replace the battery with? Can I re-apply the rubber casing of the original battery onto a new 2032 or what?
Jarad Webb - Reply Share
Past 24 Hours: 11
Past 7 Days: 95
Past 30 Days: 339
All Time: 15,788
