Up to 20% off select tools
PlayStation 2 Power Board Replacement
Views: 55K
View statistics:
Past 24 Hours:
18
Past 7 Days:
117
Past 30 Days:
595
All Time:
54,921
Comments: 15
8 comments on steps, 7 guide comments.
Go to guide comments
Completed: 42
42 people have marked this guide "completed." Will you be next?
Favorites: 27
27 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Remove and replace your PlayStation 2's power board.
    1. PlayStation 2 Power Board Replacement, Top Cover: step 1, image 1 of 3 PlayStation 2 Power Board Replacement, Top Cover: step 1, image 2 of 3 PlayStation 2 Power Board Replacement, Top Cover: step 1, image 3 of 3
      • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
      • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
      • Remove the following eight screws securing the top cover to the bottom case:
      • Four 55.4 mm Philips screws
      • Four 18.0 mm Phillips screws
      Ask FixBot
    2. PlayStation 2 Power Board Replacement: step 2, image 1 of 1
      • Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
      • The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
      Ask FixBot
    3. PlayStation 2 Power Board Replacement: step 3, image 1 of 1
      • Peel the warranty sticker (located next to the main power switch) straight away from the case.
      • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
      Ask FixBot
    4. PlayStation 2 Power Board Replacement: step 4, image 1 of 2 PlayStation 2 Power Board Replacement: step 4, image 2 of 2
      • Flip the PlayStation 2 back to its original upside position.
      • Lift the top cover off the bottom case.
      • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
      • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the top case.
      Ask FixBot
    1. PlayStation 2 Power Board Replacement, Power Board: step 5, image 1 of 2 PlayStation 2 Power Board Replacement, Power Board: step 5, image 2 of 2
      • Remove the two 6.4 mm black Phillips screws securing the optical disc drive to the bottom case.
      • Lift and remove the optical disc drive straight up out of the bottom case.
      Ask FixBot
    2. PlayStation 2 Power Board Replacement: step 6, image 1 of 2 PlayStation 2 Power Board Replacement: step 6, image 2 of 2
      • Remove the two 14.6 mm gold-headed Phillips securing the controller ports to the bottom case.
      Ask FixBot
    3. PlayStation 2 Power Board Replacement: step 7, image 1 of 2 PlayStation 2 Power Board Replacement: step 7, image 2 of 2
      • Gently lift the controller port board out of its recess within the bottom case.
      • Do not completely remove the controller port board. It is still attached via a ribbon cable.
      • Pull the controller port ribbon cable straight away from its socket on the controller port board.
      • Remove the controller port board out of the bottom case.
      Ask FixBot
    4. PlayStation 2 Power Board Replacement: step 8, image 1 of 1
      • Remove the two 14.6 mm gold Phillips screws securing the fan to the bottom case.
      Ask FixBot
    5. PlayStation 2 Power Board Replacement: step 9, image 1 of 1
      • If there is a device occupying the expansion bay, make sure to remove the device. The expansion base should be empty.
      • Pry and remove the expansion bay cover away from its posts on the bottom case.
      Ask FixBot
    6. PlayStation 2 Power Board Replacement: step 10, image 1 of 1
      • Lift the motherboard assembly from its front edge and remove it from the lower case.
      Ask FixBot
    7. PlayStation 2 Power Board Replacement: step 11, image 1 of 1
      • Now that all of that bulky plastic is out of the way, we can get to the fun stuff - electronics!
      • Remove the four 7.6 mm gold-head Phillips securing the power supply to the motherboard assembly.
      Ask FixBot
    8. PlayStation 2 Power Board Replacement: step 12, image 1 of 1
      • Lift the expansion bay cage up off the motherboard assembly.
      Ask FixBot
    9. PlayStation 2 Power Board Replacement: step 13, image 1 of 2 PlayStation 2 Power Board Replacement: step 13, image 2 of 2
      • Do not remove the power board yet. It is still attached to the motherboard assembly via the power board connector (highlighted in the first picture), which is located next to the main power switch.
      • Carefully lift the power board. You should now see the power board connector attached to the power board.
      • Pull the power board connector straight to lift it out of its socket on the power board.
      Ask FixBot
42 other people completed this guide.
Author
with
jwyoung
3,262 Reputation
5 Guides authored
Cal Poly, Team 19-1, Maness Fall 2009 Member of Cal Poly, Team 19-1, Maness Fall 2009
CPSU-MANESS-F09S19G1
4 Members
72 Guides authored
7 Guide Comments
Where do I buy the new Power Board?
chanceman75 - Reply Share
Where can you buy a new power board?
Logan Jorgensen - Reply Share
Can u replace the fuse.?
brincp - Reply Share
good news for us
VBlakeney - Reply Share
Merci beaucoup, vous ĂȘtes le meilleur et le meilleur
Rahef Love - Reply Share
Past 24 Hours: 18
Past 7 Days: 117
Past 30 Days: 595
All Time: 54,921
