PlayStation 2 Optical Disc Drive Lens Cleaning
    1. PlayStation 2 Optical Disc Drive Lens Cleaning, Top Cover: step 1, image 1 of 3 PlayStation 2 Optical Disc Drive Lens Cleaning, Top Cover: step 1, image 2 of 3 PlayStation 2 Optical Disc Drive Lens Cleaning, Top Cover: step 1, image 3 of 3
      • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
      • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
      • Remove the following eight screws securing the top cover to the bottom case:
      • Four 55.4 mm Philips screws
      • Four 18.0 mm Phillips screws
      Ask FixBot
    2. PlayStation 2 Optical Disc Drive Lens Cleaning: step 2, image 1 of 1
      • Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
      • The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
      Ask FixBot
    3. PlayStation 2 Optical Disc Drive Lens Cleaning: step 3, image 1 of 1
      • Peel the warranty sticker (located next to the main power switch) straight away from the case.
      • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
      Ask FixBot
    4. PlayStation 2 Optical Disc Drive Lens Cleaning: step 4, image 1 of 2 PlayStation 2 Optical Disc Drive Lens Cleaning: step 4, image 2 of 2
      • Flip the PlayStation 2 back to its original upside position.
      • Lift the top cover off the bottom case.
      • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
      • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the top case.
      Ask FixBot
    1. PlayStation 2 Optical Disc Drive Lens Cleaning, PlayStation 2 Optical Disc Drive Lens Cleaning: step 5, image 1 of 2 PlayStation 2 Optical Disc Drive Lens Cleaning, PlayStation 2 Optical Disc Drive Lens Cleaning: step 5, image 2 of 2
      • Remove the four 6.4 mm Phillips screws securing the top lid of the optical disc drive.
      • Lift and remove the lid from the optical disc drive.
      Ask FixBot
    2. PlayStation 2 Optical Disc Drive Lens Cleaning: step 6, image 1 of 1
      • Carefully wipe the lens in a circular motion with a rubbing alcohol damped Q-Tip.
      • Do not over-dampen the Q-Tip with rubbing alcohol.
      • Allow a few minutes for the rubbing alcohol to evaporate.
      Ask FixBot
74 other people completed this guide.
emessers
2,969 Reputation
1 Guide authored
Cal Poly, Team 19-1, Maness Fall 2009 Member of Cal Poly, Team 19-1, Maness Fall 2009
CPSU-MANESS-F09S19G1
4 Members
72 Guides authored
10 Guide Comments
I've tried the steps mentioned above to no avail. The problem persist. Anything else i can do besides purchasing another console? Sentimental value.Thank you.
Albie - Reply Share
What I'm gonna try and do is take a laser from a PC DVD burner tray and see if I reads things. It's a long shot but you can't break what's already broken ehh. I'll let you know what happens. And if it works I will write the proper tutorial for it:)
Yuri weinberg - Reply Share
HOw to use a lens cleaner dvd in Ps2
sajidsahito110 - Reply Share
please answer my problem
Hi
I have problem with my ps2 when I put the cd in the screen says that it's reading the cd but after a few minutes it stops and says no data.
What should I do ? how do I fix it ? And any clues on what to do?
Arif Ali - Reply Share
Past 24 Hours: 24
Past 7 Days: 168
Past 30 Days: 1,278
All Time: 135,942
