PlayStation 2 Disc Tray Belt Replacement
    1. PlayStation 2 Disc Tray Belt Replacement, Remove the disk dirver: step 1, image 1 of 2 PlayStation 2 Disc Tray Belt Replacement, Remove the disk dirver: step 1, image 2 of 2
      • Open the console case and remove the disk driver.
      • Be careful with the flat cables and its connectors.
      Ask FixBot
    2. PlayStation 2 Disc Tray Belt Replacement, Remove the protection: step 2, image 1 of 3 PlayStation 2 Disc Tray Belt Replacement, Remove the protection: step 2, image 2 of 3 PlayStation 2 Disc Tray Belt Replacement, Remove the protection: step 2, image 3 of 3
      • Remove the disk tray and remove the gear plastic conver protection.
      • You dont need to remove any gear form its place.
      • Remove the old belt and replace with a new one.
      • The belt must be a PS2 fat compatible belt. If you don't have a PS2 you can use a radio K7 driver belt but it need to have the same diameter of the PS2 belt.
      • Old and lax belt.
      • Brand new belt.
      Ask FixBot
    3. PlayStation 2 Disc Tray Belt Replacement, Clean the lens: step 3, image 1 of 1
      • Don't loose the opportunity and clean the laser lens with a cotton swab.
      Ask FixBot
Finish Line
9 other people completed this guide.
Vinicius Rodrigues Bellini
1,215 Reputation
6 Guides authored
4 Guide Comments
Anyone has the measurements of this belt? What’s the thickness and what’s the diameter or circumference?
Joel - Reply Share
I head 40mm diameter and 1,2mm thickness should fit fine.
Markus Ro - Reply Share
Anyone has the dimensions of this belt?
What’s the circumference/radius? What’s the thickness?
Joel - Reply Share
Sd okuyucu calısmıyor
alpercelal çam - Reply Share
Past 24 Hours: 16
Past 7 Days: 143
Past 30 Days: 634
All Time: 17,378
