Plastic Phone Case Crack/Break Repair
    1. Plastic Phone Case Crack/Break Repair, Plastic Phone Case Crack/Break Repair: step 1, image 1 of 3 Plastic Phone Case Crack/Break Repair, Plastic Phone Case Crack/Break Repair: step 1, image 2 of 3 Plastic Phone Case Crack/Break Repair, Plastic Phone Case Crack/Break Repair: step 1, image 3 of 3
      • Clean the cracked area of your phone case with a microfiber towel.
      Ask FixBot
    2. Plastic Phone Case Crack/Break Repair: step 2, image 1 of 2 Plastic Phone Case Crack/Break Repair: step 2, image 2 of 2
      • Sand down the area until smooth.
      Ask FixBot
    3. Plastic Phone Case Crack/Break Repair: step 3, image 1 of 3 Plastic Phone Case Crack/Break Repair: step 3, image 2 of 3 Plastic Phone Case Crack/Break Repair: step 3, image 3 of 3
      • Inject JB Weld epoxy into the provided mixing tray or a container of choice.
      • Use a disposable stick to mix the two elements into a homogeneous solution.
      Ask FixBot
    4. Plastic Phone Case Crack/Break Repair: step 4, image 1 of 2 Plastic Phone Case Crack/Break Repair: step 4, image 2 of 2
      • Use tape to hold the cracked or broken pieces firmly in place, ensuring the edges stay aligned maximizing contact.
      Ask FixBot
    5. Plastic Phone Case Crack/Break Repair: step 5, image 1 of 3 Plastic Phone Case Crack/Break Repair: step 5, image 2 of 3 Plastic Phone Case Crack/Break Repair: step 5, image 3 of 3
      • Grab a small stick or any disposable tool.
      • Generously apply the mixed epoxy along the crack. Make sure to get some epoxy on the internal broken edges.
      Ask FixBot
    6. Plastic Phone Case Crack/Break Repair: step 6, image 1 of 1
      • Once applied, wait 15 minutes for the epoxy to set.
      • Test epoxy strength.
      Ask FixBot
    7. Plastic Phone Case Crack/Break Repair: step 7, image 1 of 1
      • Remove the tape holding the phone case together after the epoxy has cured for long enough for the bonded pieces to stay together.
      Ask FixBot
    8. Plastic Phone Case Crack/Break Repair: step 8, image 1 of 2 Plastic Phone Case Crack/Break Repair: step 8, image 2 of 2
      • Apply epoxy to other side of phone case crack.
      Ask FixBot
    9. Plastic Phone Case Crack/Break Repair: step 9, image 1 of 3 Plastic Phone Case Crack/Break Repair: step 9, image 2 of 3 Plastic Phone Case Crack/Break Repair: step 9, image 3 of 3
      • Wait for 30 minutes for epoxy to cure fully before sanding.
      • Sand the bonded section until smooth.
      • Repeat on the inner side of phone case.
      Ask FixBot
Finish Line
StephenH
169 Reputation
1 Guide authored
UC Davis, Team 1-6, Morris Spring 2025 Member of UC Davis, Team 1-6, Morris Spring 2025
UCD-MORRIS-S25S1G6
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 16
Past 7 Days: 79
Past 30 Days: 341
All Time: 1,803
