Up to 20% off select tools
Plastic Buckle Replacement
Views: 5.8K
View statistics:
Past 24 Hours:
17
Past 7 Days:
82
Past 30 Days:
368
All Time:
5,789
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Very easy
Patagonia
Patagonia and iFixit are celebrating the stories we wear by collaborating to provide guides for Patagonia's most popular apparel repairs.
Parts
Tools
Introduction
Go to step 1 ↓
Plastic buckles are common on many Patagonia items, particularly packs, where they are used to fasten and secure straps. The most common reason for failure is when the plastic cracks or breaks.
This guide will demonstrate how to replace a plastic buckle without the need for sewing. To ensure this solution is applicable, confirm that the damaged buckle can be threaded off the item without undoing any stitches.
Read through the entire guide before starting the repair, and gather the necessary tools and materials. While Patagonia-specific materials are ideal, they are not required. Patagonia replacement parts can be obtained by calling or messaging Patagonia Customer Service.
Alternatively, Patagonia products can be taken to a local retail store for repair evaluation or sent in to Patagonia through their mail-in repair service.
Let's get fixing!
WARNING! Small Parts. Patagonia does not recommend conducting these repairs on garments intended for children age 3 or under. Instead, we recommend return of the product for professional repair services.
Return to the Patagonia Care & Repair homepage.
    1. Plastic Buckle Replacement, Assess the damage: step 1, image 1 of 3 Plastic Buckle Replacement, Assess the damage: step 1, image 2 of 3 Plastic Buckle Replacement, Assess the damage: step 1, image 3 of 3
      • Identify which piece of the buckle is damaged or missing.
      • Take note of how both sides of the buckle are attached and how the webbing is oriented.
      • It may be helpful to take a photo if the mechanism is complex.
      • If the buckle is missing entirely, see Step 5 for tips.
      Ask FixBot
    2. Plastic Buckle Replacement, Choose the replacement piece: step 2, image 1 of 3 Plastic Buckle Replacement, Choose the replacement piece: step 2, image 2 of 3 Plastic Buckle Replacement, Choose the replacement piece: step 2, image 3 of 3
      • Ensure the replacement piece fits the original piece by clipping the pieces together.
      • If you can't find a piece that fits, or if the entire buckle is missing, replace both sides of the buckle with a new set.
      Ask FixBot
    3. Plastic Buckle Replacement, Remove the damaged buckle piece: step 3, image 1 of 3 Plastic Buckle Replacement, Remove the damaged buckle piece: step 3, image 2 of 3 Plastic Buckle Replacement, Remove the damaged buckle piece: step 3, image 3 of 3
      • Slide the damaged buckle piece to the end of the webbing.
      • Maneuver one edge of the folded webbing into the buckle piece slot.
      • Use needle nose pliers to grip this edge and pull the rest of the folded end through the buckle piece slot.
      • Discard the damaged buckle piece responsibly.
      • If the buckle won't come off the webbing end, it's likely not designed to be removed and requires a sewn repair.
      Ask FixBot
    4. Plastic Buckle Replacement, Install the new buckle piece and test its functionality: step 4, image 1 of 3 Plastic Buckle Replacement, Install the new buckle piece and test its functionality: step 4, image 2 of 3 Plastic Buckle Replacement, Install the new buckle piece and test its functionality: step 4, image 3 of 3
      • Check the notes or reference photo from Step 1 to make sure the orientation is correct.
      • Repeat the technique used in Step 3 in reverse by feeding one corner of the folded webbing end into the buckle piece slot first, then using pliers to pull it all the way through.
      • Pull the webbing on each side of the buckle to ensure that it holds tension on the new piece. If the webbing slides, it may be threaded incorrectly.
      Ask FixBot
    5. Plastic Buckle Replacement, Troubleshooting: step 5, image 1 of 3 Plastic Buckle Replacement, Troubleshooting: step 5, image 2 of 3 Plastic Buckle Replacement, Troubleshooting: step 5, image 3 of 3
      • MISSING BUCKLE: If the entire buckle is missing and it's not clear how it was originally oriented on the webbing, follow these guidelines:
      • A replacement buckle is sized by the width of the webbing it will be attached to.
      • As a general rule, when fastening a buckle while wearing an item, the release piece (insert) is held in the right hand while the lock piece (receiver) is held in the left hand.
      • VARIATIONS: Sometimes only one side of the buckle will be replaceable, like when one side is sewn onto a backpack.
      Ask FixBot
Finish Line
Author
with
Clara Redwood
2,574 Reputation
19 Guides authored
Patagonia Member of Patagonia
Community
9 Members
384 Guides authored
0 Guide Comments
Past 24 Hours: 17
Past 7 Days: 82
Past 30 Days: 368
All Time: 5,789
