Plantronics WH100 Savi Go Battery replacement
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
63
All Time:
704
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Introduction
Go to step 1 ↓
Tools: Cutter, Dremel with milling cutter tip
Spare parts: 1 piece battery Plantronics 70868-01 Li-ion-plm 0.444Wh
The housing CANNOT be opened non-destructively, the housing is not designed for repair. The two halves of the thick electronics compartment are held together by four tabs. The tabs are glued. The binding points on the microphone neck remain closed during the repair.
To gently open the electronics compartment, the 4 tabs must be separated. The tab positions are 20mm and 52mm from the rear of the headset.
2 options:
A: Cut tab
or B: Mill a groove on each side of the housing at the specified positions to expose the lug. Release the tabs and open the housing.
Desolder the battery, change it and solder in the new battery.
Temporarily plug the housing together and charge the headset.
If it works, close the case
A: If the tabs were cut off, secure the case halves with tape or reattach them with liquid glue.
B: After changing the battery, re-glue the tabs of the housing cover to the underside of the housing and close the grooves evenly.
    1. Plantronics WH100 Savi Go Battery replacement, Battery: step 1, image 1 of 2 Plantronics WH100 Savi Go Battery replacement, Battery: step 1, image 2 of 2
      • Tab positions at 20mm and 52mm from case end
      Ask FixBot
    2. Plantronics WH100 Savi Go Battery replacement: step 2, image 1 of 2 Plantronics WH100 Savi Go Battery replacement: step 2, image 2 of 2
      • Battery Plantronics 70868-01
      Ask FixBot
Finish Line
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Sascha Köppel
97 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 63
All Time: 704
