Plantronics Voyager Legend Earpiece Replacement
  1. Plantronics Voyager Legend Earpiece Replacement, Earpiece: step 1, image 1 of 3 Plantronics Voyager Legend Earpiece Replacement, Earpiece: step 1, image 2 of 3 Plantronics Voyager Legend Earpiece Replacement, Earpiece: step 1, image 3 of 3
    • Remove the soft, plastic earpiece.
    • Depress the soft, plastic earpiece. While depressed, rotate the earpiece counterclockwise ninety degrees.
    • List the soft, plastic earpiece out of its position.
    Ask FixBot
  2. Plantronics Voyager Legend Earpiece Replacement: step 2, image 1 of 1
    • Heat the earpiece assembly with a heat gun (a hair dryer will work if a heat gun is not available).
    • The heating softens the adhesive that holds the assembly together, and the assembly may need to be reheated to complete the dis-assembly process.
    Ask FixBot
  3. Plantronics Voyager Legend Earpiece Replacement: step 3, image 1 of 2 Plantronics Voyager Legend Earpiece Replacement: step 3, image 2 of 2
    • The two snaps that combine with the adhesive to hold the assembly together are located in the neck of the earpiece unit.
    Ask FixBot
  4. Plantronics Voyager Legend Earpiece Replacement: step 4, image 1 of 2 Plantronics Voyager Legend Earpiece Replacement: step 4, image 2 of 2
    • Remove the top half of the earpiece assembly.
    • Use the pointed end of a small, metal Spudger to loosen the two tabs that hold the earpiece assembly together.
    • While glue is soft and snaps are loosened, remove the entire top half of the earpiece housing.
    Ask FixBot
  5. Plantronics Voyager Legend Earpiece Replacement: step 5, image 1 of 3 Plantronics Voyager Legend Earpiece Replacement: step 5, image 2 of 3 Plantronics Voyager Legend Earpiece Replacement: step 5, image 3 of 3
    • Remove the speaker housing.
    • With the copper backing plate displayed, use the pointed end of a small, metal Spudger to disassemble the speaker housing.
    • Using the pointed end of the small, metal Spudger, lift the copper, backing plate away from the speaker unit.
    Ask FixBot
  6. Plantronics Voyager Legend Earpiece Replacement: step 6, image 1 of 2 Plantronics Voyager Legend Earpiece Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Use Precision Tweezers to remove the protective screen from the front of the speaker unit.
    Ask FixBot
  7. Plantronics Voyager Legend Earpiece Replacement: step 7, image 1 of 3 Plantronics Voyager Legend Earpiece Replacement: step 7, image 2 of 3 Plantronics Voyager Legend Earpiece Replacement: step 7, image 3 of 3
    • Remove the speaker unit and solder a new unit in place.
    • When disconnecting leads, always disconnect as near as possible to the component being replaced, to allow room for reattachment.
    • Locate the leads that connect to the back of the speaker unit.
    • Disconnect the leads from the back of the speaker unit.
    • Remove the speaker unit, and replace by soldering the leads back into their correct locations.
    • Refer to the iFixit soldering guide for assistance with soldering.
    Ask FixBot
7 other people completed this guide.
Lewis Certain
2,355 Reputation
3 Guides authored
1 Guide Comment
Thank you for the Guide.
One further Question is open for me: How do you replace the broken rubber near the earpiece?
albert einstein - Reply Share
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 57
All Time: 17,478
