Up to 20% off select tools
Plantronics CS50 Headset System Reset
Views: 24K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
97
All Time:
23,788
Comments: 4
4 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
If your headset had been working great but suddenly started producing static or distorted sounds, you may need to reset your headset. Follow these instructions:
    1. Plantronics CS50 Headset System Reset, Plantronics CS50 Headset System Reset: step 1, image 1 of 2 Plantronics CS50 Headset System Reset, Plantronics CS50 Headset System Reset: step 1, image 2 of 2
      • Press and hold both the call control button and the listening volume/mute button for five seconds.
      • When the talk indicator light blinks, release both buttons.
      Ask FixBot
    2. Plantronics CS50 Headset System Reset: step 2, image 1 of 1
      • Press the call control button again.
      Ask FixBot
    3. Plantronics CS50 Headset System Reset: step 3, image 1 of 2 Plantronics CS50 Headset System Reset: step 3, image 2 of 2
      • Unplug the base unit's power source for ten seconds.
      • Plug the power source back in.
      Ask FixBot
Finish Line
3 other people completed this guide.
Author
with
Joe
117 Reputation
3 Guides authored
Cal Poly, Team 17-29, Amido Spring 2012 Member of Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 Members
84 Guides authored
4 Guide Comments
Great fix. I was about to spend $200 on a new set. Thanks.
acseko - Reply Share
I had a constant buzzing sound from the unit. I did what you recommended and could not stop it. Then I discovered that my handset also had the same buzzing sound so I unplugged the phone line and power cord (to the main phone unit) and it cleared up!
Russ - Reply Share
I've got a unit that is getting no sound to or from the earpiece at all, though the lifter still lifts when I hit the answer button. I'll try this reset before I order a replacement set.
kool1zero - Reply Share
I have the C053 model and have cleaned headset and base and can not get it to charge. I have noticed over the past few weeks that it will only stayed charged from 800 am to 100 pm. I have disconnected and restarted also. Any other suggestions?
Diane
Diane - Reply Share
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 97
All Time: 23,788
