Up to 20% off select tools
Plantronics CS50 Headset Synchronization
Views: 2.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
87
All Time:
2,501
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
The base unit and headset are synchronized together when you bought them. So if you want to use a replacement headset with the base unit (or if you lose your connection to the base unit) you will need to follow these steps to synchronize the headset to the base:
    1. Plantronics CS50 Headset Synchronization, Plantronics CS50 Headset Synchronization: step 1, image 1 of 1
      • Ensure the headset is in the base's cradle.
      Ask FixBot
    2. Plantronics CS50 Headset Synchronization: step 2, image 1 of 1
      • Press the volume control buttons on the back of the base until the front of the base flashes red.
      Ask FixBot
    3. Plantronics CS50 Headset Synchronization: step 3, image 1 of 1
      • Press the mute switch on top of the headset until the green light on the headset turns on.
      Ask FixBot
    4. Plantronics CS50 Headset Synchronization: step 4, image 1 of 2 Plantronics CS50 Headset Synchronization: step 4, image 2 of 2
      • Unplug the power cord for five seconds. After the five seconds are over, reconnect the power cord.
      Ask FixBot
    5. Plantronics CS50 Headset Synchronization: step 5, image 1 of 1
      • When the flashing red light becomes solid, synchronization is complete.
      Ask FixBot
Finish Line
3 other people completed this guide.
Author
with
Joe
117 Reputation
3 Guides authored
Cal Poly, Team 17-29, Amido Spring 2012 Member of Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 87
All Time: 2,501
