Plantronics CS50 Headset Motherboard of the Base Unit Replacement
  1. Plantronics CS50 Headset Motherboard of the Base Unit Replacement, Motherboard of the Base Unit: step 1, image 1 of 2 Plantronics CS50 Headset Motherboard of the Base Unit Replacement, Motherboard of the Base Unit: step 1, image 2 of 2
    • Flip over the base unit to reveal the bottom.
    Ask FixBot
  2. Plantronics CS50 Headset Motherboard of the Base Unit Replacement: step 2, image 1 of 2 Plantronics CS50 Headset Motherboard of the Base Unit Replacement: step 2, image 2 of 2
    • Using a #0 screwdriver, remove the two 2.50mm screws.
    Ask FixBot
  3. Plantronics CS50 Headset Motherboard of the Base Unit Replacement: step 3, image 1 of 3 Plantronics CS50 Headset Motherboard of the Base Unit Replacement: step 3, image 2 of 3 Plantronics CS50 Headset Motherboard of the Base Unit Replacement: step 3, image 3 of 3
    • Separate, but do not remove, the silver upper piece from the dark lower piece.
    • Carefully disconnect the wires from the motherboard.
    • Remove the silver top of the base.
    Ask FixBot
  4. Plantronics CS50 Headset Motherboard of the Base Unit Replacement: step 4, image 1 of 3 Plantronics CS50 Headset Motherboard of the Base Unit Replacement: step 4, image 2 of 3 Plantronics CS50 Headset Motherboard of the Base Unit Replacement: step 4, image 3 of 3
    • Remove the motherboard from the base
    Ask FixBot
Bryan Clark
51 Reputation
1 Guide authored
Cal Poly, Team 17-29, Amido Spring 2012 Member of Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 1,335
