Plantronics CS50 Headset Motherboard Replacement
    1. Plantronics CS50 Headset Motherboard Replacement, Battery: step 1, image 1 of 3 Plantronics CS50 Headset Motherboard Replacement, Battery: step 1, image 2 of 3 Plantronics CS50 Headset Motherboard Replacement, Battery: step 1, image 3 of 3
      • Flip the headset face down.
      • Squeeze both sides of the battery cover.
      • While squeezing, pull the cover up slowly to remove it.
      Ask FixBot
    2. Plantronics CS50 Headset Motherboard Replacement: step 2, image 1 of 3 Plantronics CS50 Headset Motherboard Replacement: step 2, image 2 of 3 Plantronics CS50 Headset Motherboard Replacement: step 2, image 3 of 3
      • Locate and detatch the white connector that connects the wires of the battery to the wires of the headset.
      Ask FixBot
    1. Plantronics CS50 Headset Motherboard Replacement, Microphone: step 3, image 1 of 2 Plantronics CS50 Headset Motherboard Replacement, Microphone: step 3, image 2 of 2
      • Use a hairdryer or heat gun to melt the adhesive along the crevice that joins the black and silver components.
      • Apply additional heat at the tip of the microphone.
      Ask FixBot
    2. Plantronics CS50 Headset Motherboard Replacement: step 4, image 1 of 2 Plantronics CS50 Headset Motherboard Replacement: step 4, image 2 of 2
      • After heating the headset, use the plastic opening tool to carefully pry the black cover from the headset.
      • Be aware of the two plastic connectors inside the headset. If the black cover does not come off smoothly, apply additional heat on the connectors.
      Ask FixBot
    3. Plantronics CS50 Headset Motherboard Replacement: step 5, image 1 of 2 Plantronics CS50 Headset Motherboard Replacement: step 5, image 2 of 2
      • Remove the microphone from the tip of the plastic.
      • You will have to lift the microphone straight up because it is held in place by a small piece of plastic.
      Ask FixBot
    4. Plantronics CS50 Headset Motherboard Replacement: step 6, image 1 of 2 Plantronics CS50 Headset Motherboard Replacement: step 6, image 2 of 2
      • Use the heat gun to melt the adhesive connecting the headset face to the speaker casing.
      • Use the plastic opening tool to separate the speaker casing from the headset face.
      • Add extra heat to the sides to melt the adhesive between the plastic connectors.
      Ask FixBot
    5. Plantronics CS50 Headset Motherboard Replacement: step 7, image 1 of 2 Plantronics CS50 Headset Motherboard Replacement: step 7, image 2 of 2
      • Slowly separate the motherboard from the rest of the headset.
      Ask FixBot
    6. Plantronics CS50 Headset Motherboard Replacement: step 8, image 1 of 1
      • Locate the microphone wires on the bottom of the motherboard.
      • Use a hairdryer or heat gun to melt the glue off of the motherboard.
      Ask FixBot
    7. Plantronics CS50 Headset Motherboard Replacement: step 9, image 1 of 1
      • Flip the device over.
      • Use a soldering iron to remove the solder that holds the wires to the motherboard.
      • For help soldering, click here.
      • The microphone piece should be completely detached from the motherboard.
      Ask FixBot
    1. Plantronics CS50 Headset Motherboard Replacement, Motherboard: step 10, image 1 of 3 Plantronics CS50 Headset Motherboard Replacement, Motherboard: step 10, image 2 of 3 Plantronics CS50 Headset Motherboard Replacement, Motherboard: step 10, image 3 of 3
      • Using a blow dryer or a heat gun, heat the crevice to melt the adhesive between the plastic covers.
      • Using a plastic opening tool, prop open the edges.
      • Gently pull the black speaker casing up to remove it.
      Ask FixBot
    2. Plantronics CS50 Headset Motherboard Replacement: step 11, image 1 of 2 Plantronics CS50 Headset Motherboard Replacement: step 11, image 2 of 2
      • Use the heat gun or blow dryer to melt the glue that connects the wires to the headset's motherboard.
      • The wires should come off as they are not soldered to the motherboard.
      Ask FixBot
Joe
117 Reputation
3 Guides authored
Cal Poly, Team 17-29, Amido Spring 2012 Member of Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 Members
83 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 28
All Time: 1,344
