Planet Eclipse Geo3 Eyes Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
80
All Time:
1,586
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show how to replace the eyes and eye wire if either are damaged.
    1. Planet Eclipse Geo3 Eyes Replacement, Grip: step 1, image 1 of 2 Planet Eclipse Geo3 Eyes Replacement, Grip: step 1, image 2 of 2
      • Remove the four screws from the grip with the 5/64" allen wrench. There are two on each side.
      Ask FixBot
    2. Planet Eclipse Geo3 Eyes Replacement: step 2, image 1 of 2 Planet Eclipse Geo3 Eyes Replacement: step 2, image 2 of 2
      • Pull the grip away from the frame.
      Ask FixBot
    3. Planet Eclipse Geo3 Eyes Replacement: step 3, image 1 of 2 Planet Eclipse Geo3 Eyes Replacement: step 3, image 2 of 2
      • Pull the grip through the opening.
      • The grip is connected in the middle and is one piece.
      Ask FixBot
    1. Planet Eclipse Geo3 Eyes Replacement, Macroline: step 4, image 1 of 3 Planet Eclipse Geo3 Eyes Replacement, Macroline: step 4, image 2 of 3 Planet Eclipse Geo3 Eyes Replacement, Macroline: step 4, image 3 of 3
      • Remove the macroline from the fitting by pulling the metal ring around the end of the fitting away while pulling out the macroline.
      • It helps to rotate the collar to create room to pull out macroline.
      Ask FixBot
    2. Planet Eclipse Geo3 Eyes Replacement: step 5, image 1 of 3 Planet Eclipse Geo3 Eyes Replacement: step 5, image 2 of 3 Planet Eclipse Geo3 Eyes Replacement: step 5, image 3 of 3
      • While pulling in the metal ring on the fitting, pull the macroline out.
      Ask FixBot
    1. Planet Eclipse Geo3 Eyes Replacement, Body: step 6, image 1 of 3 Planet Eclipse Geo3 Eyes Replacement, Body: step 6, image 2 of 3 Planet Eclipse Geo3 Eyes Replacement, Body: step 6, image 3 of 3
      • Use 1/8" allen wrench to remove screw behind regulator.
      Ask FixBot
    2. Planet Eclipse Geo3 Eyes Replacement: step 7, image 1 of 3 Planet Eclipse Geo3 Eyes Replacement: step 7, image 2 of 3 Planet Eclipse Geo3 Eyes Replacement: step 7, image 3 of 3
      • Use 1/8" allen wrench to loosen the screw inside the grip on the right side.
      • The screw only needs to be turned a couple of times.
      • Slide the upper frame forward on the rails and remove the screw from the slot to separate the two halves of the body.
      • BE CAREFUL: Do not pull the two frames apart too much or too quickly. This may cause the wires to be damaged.
      Ask FixBot
    1. Planet Eclipse Geo3 Eyes Replacement, Eyes: step 8, image 1 of 3 Planet Eclipse Geo3 Eyes Replacement, Eyes: step 8, image 2 of 3 Planet Eclipse Geo3 Eyes Replacement, Eyes: step 8, image 3 of 3
      Tool used on this step:
      Buy
      • Use a prying tool or tweezers to gently remove the connection from the board. It is the connection with 2 black and 2 red wires.
      • Pull the wire through the opening.
      Ask FixBot
    2. Planet Eclipse Geo3 Eyes Replacement: step 9, image 1 of 3 Planet Eclipse Geo3 Eyes Replacement: step 9, image 2 of 3 Planet Eclipse Geo3 Eyes Replacement: step 9, image 3 of 3
      • Use 5/64" allen key to remove each screw from eye covers (Located on both sides of the paintball marker.)
      • Pull off eye covers. (Located on both sides of the paintball marker.)
      Ask FixBot
    3. Planet Eclipse Geo3 Eyes Replacement: step 10, image 1 of 3 Planet Eclipse Geo3 Eyes Replacement: step 10, image 2 of 3 Planet Eclipse Geo3 Eyes Replacement: step 10, image 3 of 3
      • Gently pull out the two eyes, one on each side of the paintball marker.
      • The red wire leading to the eye on the right side of the paintball marker. The black wire leads to the eye on the left side.
      Ask FixBot
To reassemble your device with a new eye wire, follow this guide in reverse.
Rett Triplett
801 Reputation
8 Guides authored
Clemson, Team 13-6, Benson Fall 2013 Member of Clemson, Team 13-6, Benson Fall 2013
CLEM-BENSON-F13S13G6
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 80
All Time: 1,586
