Planet Eclipse Geo3 Battery Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
83
All Time:
1,536
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
    1. Planet Eclipse Geo3 Battery Replacement, Grip: step 1, image 1 of 2 Planet Eclipse Geo3 Battery Replacement, Grip: step 1, image 2 of 2
      • Remove the four screws from the grip with the 5/64" allen wrench. There are two on each side.
      Ask FixBot
    2. Planet Eclipse Geo3 Battery Replacement: step 2, image 1 of 2 Planet Eclipse Geo3 Battery Replacement: step 2, image 2 of 2
      • Pull the grip away from the frame.
      Ask FixBot
    3. Planet Eclipse Geo3 Battery Replacement: step 3, image 1 of 2 Planet Eclipse Geo3 Battery Replacement: step 3, image 2 of 2
      • Pull the grip through the opening.
      • The grip is connected in the middle and is one piece.
      Ask FixBot
    1. Planet Eclipse Geo3 Battery Replacement, Battery: step 4, image 1 of 2 Planet Eclipse Geo3 Battery Replacement, Battery: step 4, image 2 of 2
      • Push out top of battery from left side of grip.
      Ask FixBot
    2. Planet Eclipse Geo3 Battery Replacement: step 5, image 1 of 1
      • Push new battery into right side of grip, inserting the bottom first.
      • Be sure to match the signs of the battery and the terminals. The terminals are labeled just above the battery on the right side.
      Ask FixBot
To reassemble your device, follow the Disassembling Planet Eclipse Geo3 Grip in reverse.
Rett Triplett
801 Reputation
8 Guides authored
Clemson, Team 13-6, Benson Fall 2013 Member of Clemson, Team 13-6, Benson Fall 2013
CLEM-BENSON-F13S13G6
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 83
All Time: 1,536
