Up to 20% off select tools
Planet Eclipse Etha Trigger Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
99
All Time:
1,544
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
The trigger on the Etha doesn't break often, but you may choose to replace it for a trigger you prefer or it may simply need cleaning.
    1. Planet Eclipse Etha Trigger Replacement, Battery and Grip Panels: step 1, image 1 of 2 Planet Eclipse Etha Trigger Replacement, Battery and Grip Panels: step 1, image 2 of 2
      • Use the 5/64" hex key to remove the screw shown.
      • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
      • If you are only replacing the battery, skip the next step.
      • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
      Ask FixBot
    2. Planet Eclipse Etha Trigger Replacement: step 2, image 1 of 1
      • Flip the marker over and use the 5/64" hex key to remove the screw shown.
      Ask FixBot
    3. Planet Eclipse Etha Trigger Replacement: step 3, image 1 of 2 Planet Eclipse Etha Trigger Replacement: step 3, image 2 of 2
      • Carefully remove the 9V battery and connector.
      • Remove the 9V battery from the connector.
      Ask FixBot
    1. Planet Eclipse Etha Trigger Replacement, Trigger: step 4, image 1 of 1
      • Use a hex key to unscrew the middle screw on the top of the trigger.
      Ask FixBot
    2. Planet Eclipse Etha Trigger Replacement: step 5, image 1 of 1
      • Use same hex key to push through trigger retention pin on the side of the gun.
      Ask FixBot
    3. Planet Eclipse Etha Trigger Replacement: step 6, image 1 of 2 Planet Eclipse Etha Trigger Replacement: step 6, image 2 of 2
      • Pull out the trigger by grabbing the bottom and slowly rotating outwards.
      Ask FixBot
Author
with
Evan Hench
223 Reputation
1 Guide authored
Cal Poly, Team 10-42, Amido Fall 2014 Member of Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 99
All Time: 1,544
