Planet Eclipse Etha Solenoid Replacement
    1. Planet Eclipse Etha Solenoid Replacement, Regulator: step 1, image 1 of 2 Planet Eclipse Etha Solenoid Replacement, Regulator: step 1, image 2 of 2
      • Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun.
      • Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
      • The macroline is the black hose connecting the regulator to the tank connection.
      Ask FixBot
    2. Planet Eclipse Etha Solenoid Replacement: step 2, image 1 of 2 Planet Eclipse Etha Solenoid Replacement: step 2, image 2 of 2
      • Remove the regulator by unscrewing it in a clockwise direction.
      Ask FixBot
    1. Planet Eclipse Etha Solenoid Replacement, Battery and Grip Panels: step 3, image 1 of 2 Planet Eclipse Etha Solenoid Replacement, Battery and Grip Panels: step 3, image 2 of 2
      • Use the 5/64" hex key to remove the screw shown.
      • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
      • If you are only replacing the battery, skip the next step.
      • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
      Ask FixBot
    2. Planet Eclipse Etha Solenoid Replacement: step 4, image 1 of 1
      • Flip the marker over and use the 5/64" hex key to remove the screw shown.
      Ask FixBot
    3. Planet Eclipse Etha Solenoid Replacement: step 5, image 1 of 2 Planet Eclipse Etha Solenoid Replacement: step 5, image 2 of 2
      • Carefully remove the 9V battery and connector.
      • Remove the 9V battery from the connector.
      Ask FixBot
    1. Planet Eclipse Etha Solenoid Replacement, Frame: step 6, image 1 of 2 Planet Eclipse Etha Solenoid Replacement, Frame: step 6, image 2 of 2
      • Carefully disconnect the three connectors from the circuit board.
      • Don't worry about remembering which direction the connectors go in, they will not fit in the board in the wrong direction.
      Ask FixBot
    2. Planet Eclipse Etha Solenoid Replacement: step 7, image 1 of 2 Planet Eclipse Etha Solenoid Replacement: step 7, image 2 of 2
      • Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise.
      Ask FixBot
    3. Planet Eclipse Etha Solenoid Replacement: step 8, image 1 of 1
      • Be very careful during the step to avoid damage to the solenoid or wiring.
      • Gently separate the top and bottom of the marker.
      Ask FixBot
    1. Planet Eclipse Etha Solenoid Replacement, Solenoid: step 9, image 1 of 2 Planet Eclipse Etha Solenoid Replacement, Solenoid: step 9, image 2 of 2
      • Remove the two black hex bolts that connect the solenoid mount to the body.
      • Use the 5/64" Allen Key to rotate each screw counter clockwise.
      Ask FixBot
    2. Planet Eclipse Etha Solenoid Replacement: step 10, image 1 of 2 Planet Eclipse Etha Solenoid Replacement: step 10, image 2 of 2
      • Remove the two Phillips head screws that connect the solenoid to its mount.
      • Use a Phillip's head screwdriver and rotate each screw counter clockwise.
      • Do not attempt to dismantle the solenoid. Intentionally dismantling or tampering with the solenoid voids the manufacturer’s warranty.
      Ask FixBot
Austin Eslinger
110 Reputation
1 Guide authored
Cal Poly, Team 10-42, Amido Fall 2014 Member of Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 Members
84 Guides authored
3 Guide Comments
Watis the price on etha solenoid, where can i get one , l ma staying in SA, myne is leaking ear,email ratgonefishing @gmail. Com
Roelof Koekemoer - Reply Share
Hi my etha solenoid leaks ear,where do l get one,wats the price,i m staying in SA
Hello if it’s leaking try to lubricate your O-rings and switch out the filter, these can be very expensive from $55-$99 they don’t Make this model anymore so it’s very hard to find
Eddie - Reply Share
Past 24 Hours: 10
Past 7 Days: 32
Past 30 Days: 90
All Time: 3,109
