Planet Eclipse Etha Eyes Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
Past 7 Days:
22
Past 30 Days:
80
All Time:
1,788
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The Etha's Eyes determine there is a ball in the chamber before firing. This guide is useful for players who choose to upgrade their eyes, or for players who have a marker with broken eyes.
Tools
    1. Planet Eclipse Etha Eyes Replacement, Regulator: step 1, image 1 of 2 Planet Eclipse Etha Eyes Replacement, Regulator: step 1, image 2 of 2
      • Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun.
      • Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
      • The macroline is the black hose connecting the regulator to the tank connection.
      Ask FixBot
    2. Planet Eclipse Etha Eyes Replacement: step 2, image 1 of 2 Planet Eclipse Etha Eyes Replacement: step 2, image 2 of 2
      • Remove the regulator by unscrewing it in a clockwise direction.
      Ask FixBot
    1. Planet Eclipse Etha Eyes Replacement, Battery and Grip Panels: step 3, image 1 of 2 Planet Eclipse Etha Eyes Replacement, Battery and Grip Panels: step 3, image 2 of 2
      • Use the 5/64" hex key to remove the screw shown.
      • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
      • If you are only replacing the battery, skip the next step.
      • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
      Ask FixBot
    2. Planet Eclipse Etha Eyes Replacement: step 4, image 1 of 1
      • Flip the marker over and use the 5/64" hex key to remove the screw shown.
      Ask FixBot
    3. Planet Eclipse Etha Eyes Replacement: step 5, image 1 of 2 Planet Eclipse Etha Eyes Replacement: step 5, image 2 of 2
      • Carefully remove the 9V battery and connector.
      • Remove the 9V battery from the connector.
      Ask FixBot
    1. Planet Eclipse Etha Eyes Replacement, Frame: step 6, image 1 of 2 Planet Eclipse Etha Eyes Replacement, Frame: step 6, image 2 of 2
      • Carefully disconnect the three connectors from the circuit board.
      • Don't worry about remembering which direction the connectors go in, they will not fit in the board in the wrong direction.
      Ask FixBot
    2. Planet Eclipse Etha Eyes Replacement: step 7, image 1 of 2 Planet Eclipse Etha Eyes Replacement: step 7, image 2 of 2
      • Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise.
      Ask FixBot
    3. Planet Eclipse Etha Eyes Replacement: step 8, image 1 of 1
      • Be very careful during the step to avoid damage to the solenoid or wiring.
      • Gently separate the top and bottom of the marker.
      Ask FixBot
    1. Planet Eclipse Etha Eyes Replacement, Eyes: step 9, image 1 of 2 Planet Eclipse Etha Eyes Replacement, Eyes: step 9, image 2 of 2
      • Use the 5/64" hex key to turn the screw counterclockwise.
      • Carefully remove the screw and place it off to the side.
      • Remove the panel and place it off to the side.
      Ask FixBot
    2. Planet Eclipse Etha Eyes Replacement: step 10, image 1 of 2 Planet Eclipse Etha Eyes Replacement: step 10, image 2 of 2
      • Carefully flip the marker over.
      • Remove the screw and place it off to the side.
      • Carefully remove the panel and place it off to the side.
      Ask FixBot
    3. Planet Eclipse Etha Eyes Replacement: step 11, image 1 of 2 Planet Eclipse Etha Eyes Replacement: step 11, image 2 of 2
      • Grip the marker with one hand and gently pull the eyes out with your other hand.
      Ask FixBot
Hannah Lancaster
132 Reputation
1 Guide authored
Cal Poly, Team 10-42, Amido Fall 2014 Member of Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 80
All Time: 1,788
