Pioneer R1 Battery Replacement
    1. Pioneer R1 Battery Replacement, Battery: step 1, image 1 of 1
      • Insert your plastic spudger into the opening near the HDMI port.
      • Gently pry the back cover of the R1 from the the front by using the spudger along the edges.
      • Do not pull the back cover straight off the R1 as components of the speakers will be attached to both sides.
      Ask FixBot
    2. Pioneer R1 Battery Replacement: step 2, image 1 of 1
      • Lay the R1 flat like an open book.
      • This will prevent the speakers from becoming disconnected from the motherboard.
      Ask FixBot
    3. Pioneer R1 Battery Replacement: step 3, image 1 of 1
      • Slide a strong thin object, like a thin spudger, between the battery and the display.
      • Slide the object along the length of the battery to remove it from the display.
      • The adhesive holding the battery in place is strong and the battery is quite soft. Take care not to break open the battery.
      • Disengage the battery cables from the motherboard.
      Ask FixBot
    4. Pioneer R1 Battery Replacement: step 4, image 1 of 1
      • Solder the black cable to the nodule labeled BAT+.
      • Solder the red cable to the nodule labeled BAT-.
      • Do not allow the solder from one nodule to touch the other, this may cause the battery to explode.
      Ask FixBot
Christopher Rosario
411 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 86
All Time: 1,206
