Pioneer MXT-X366BT Metal Case Replacement
  1. Pioneer MXT-X366BT Metal Case Replacement, Metal Casing: step 1, image 1 of 2 Pioneer MXT-X366BT Metal Case Replacement, Metal Casing: step 1, image 2 of 2
    • Apply small amount of pressure inward with a plastic opening tool to release bottom clip.
    • Pry the top clip with the plastic opening tool to release it.
    • The head unit is symmetrical and has the same amount of clips on the other side.
  2. Pioneer MXT-X366BT Metal Case Replacement: step 2, image 1 of 1
    • Remove the face plate holder.
  3. Pioneer MXT-X366BT Metal Case Replacement: step 3, image 1 of 1
    • Remove the six 5mm Phillips-head screws with Philips #2 screwdriver.
  4. Pioneer MXT-X366BT Metal Case Replacement: step 4, image 1 of 2 Pioneer MXT-X366BT Metal Case Replacement: step 4, image 2 of 2
    • Remove the inner three 5mm Phillips head screws, with a Phillips #2 screwdriver, attached to the metal backing.
    • Remove the metal backing that is now free.
  5. Pioneer MXT-X366BT Metal Case Replacement: step 5, image 1 of 1
    • Carefully slide the metal casing forward.
    • Metal piece standing is the rear of the head unit.
    • Edges are sharp.
  6. Pioneer MXT-X366BT Metal Case Replacement: step 6, image 1 of 1
    • Lift the metal casing from the rear and pull it away.
    • Edges are sharp.
  7. Pioneer MXT-X366BT Metal Case Replacement: step 7, image 1 of 1
    • The metal casing is now fully removed.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 33
All Time: 485
