Pioneer FH-X730BS Disk Drive Replacement
    1. Pioneer FH-X730BS Disk Drive Replacement, Disk Drive: step 1, image 1 of 3 Pioneer FH-X730BS Disk Drive Replacement, Disk Drive: step 1, image 2 of 3 Pioneer FH-X730BS Disk Drive Replacement, Disk Drive: step 1, image 3 of 3
      • Apply pressure to the tabs on each side using the plastic opening tool.
      • You will need to pull the face away from the frame while unhooking the tabs.
      Ask FixBot
    2. Pioneer FH-X730BS Disk Drive Replacement: step 2, image 1 of 1
      • After removing the stereo face from the frame, it should look similar to this.
      Ask FixBot
    3. Pioneer FH-X730BS Disk Drive Replacement: step 3, image 1 of 1
      • Remove the ribbon wire from where it is being held in place. This can be done by applying force upwards.
      Ask FixBot
    4. Pioneer FH-X730BS Disk Drive Replacement: step 4, image 1 of 3 Pioneer FH-X730BS Disk Drive Replacement: step 4, image 2 of 3 Pioneer FH-X730BS Disk Drive Replacement: step 4, image 3 of 3
      • Unscrew the four 7.3 mm outer screws on the top to remove the top face from the rest of the frame.
      Ask FixBot
    5. Pioneer FH-X730BS Disk Drive Replacement: step 5, image 1 of 3 Pioneer FH-X730BS Disk Drive Replacement: step 5, image 2 of 3 Pioneer FH-X730BS Disk Drive Replacement: step 5, image 3 of 3
      • Unscrew the four inner screws that are 7.3 mm long using a Phillips #1 head screw driver to remove the disk drive from the top face plate.
      • Replace the old disk drive with a new one.
      Ask FixBot
Cody Pesta
688 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 25
All Time: 618
