Pine64 PinePhone Volume Buttons Replacement
Views: 1K
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
63
All Time:
1,017
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
  • Spudger
    4.9
    1. Pine64 PinePhone Volume Buttons Replacement, Place the device facing down: step 1, image 1 of 2 Pine64 PinePhone Volume Buttons Replacement, Place the device facing down: step 1, image 2 of 2
      • Place the device face down on a non-scratch surface.
      • Ensure the device is powered off before removing the case as removing the battery or making internal changes could cause physical or hardware damage to the phone
      Ask FixBot
    2. Pine64 PinePhone Volume Buttons Replacement, Remove the back cover: step 2, image 1 of 1
      • Using a fingernail pry open the back cover off with the bottom left indent.
      • A notch to easily remove the cover is located at the bottom left of the PinePhone with the back cover facing the user.
      Ask FixBot
    1. Pine64 PinePhone Volume Buttons Replacement, Battery: step 3, image 1 of 1
      • Using a fingernail, press into the bottom divot and remove the battery from the phone.
      Ask FixBot
    1. Pine64 PinePhone Volume Buttons Replacement, Motherboard: step 4, image 1 of 1
      • Use a spudger or plastic opening tool to pry off the plastic cover.
      Ask FixBot
    2. Pine64 PinePhone Volume Buttons Replacement: step 5, image 1 of 1
      • Use a spudger to lift the ZIF tabs and press-fit connectors free.
      Ask FixBot
    3. Pine64 PinePhone Volume Buttons Replacement: step 6, image 1 of 1
      • Use a spudger to lift the motherboard up and remove it from the device.
      Ask FixBot
    1. Pine64 PinePhone Volume Buttons Replacement, Volume Buttons: step 7, image 1 of 1
      • Use a spudger to gently pry the volume button off of the phone.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 63
All Time: 1,017
