Pine64 PinePhone Battery Replacement
Views: 4.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
25
Past 30 Days:
94
All Time:
4,630
Comments: 1
1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
Use this guide to replace a used, nonfunctional, or a reduced capacity battery in a Pine64 PinePhone. Batteries naturally degrade over time, so use this guide after a few years of strenuous use to give an older phone new life.
Before beginning, make sure to power off the phone and disconnect from any external power source.
Use caution. If the battery emits an odor, liquid, or is swollen, this repair may be dangerous.
    1. Pine64 PinePhone Battery Replacement, Place the device facing down: step 1, image 1 of 2 Pine64 PinePhone Battery Replacement, Place the device facing down: step 1, image 2 of 2
      • Place the device face down on a non-scratch surface.
      • Ensure the device is powered off before removing the case as removing the battery or making internal changes could cause physical or hardware damage to the phone
      Ask FixBot
    2. Pine64 PinePhone Battery Replacement, Remove the back cover: step 2, image 1 of 1
      • Using a fingernail pry open the back cover off with the bottom left indent.
      • A notch to easily remove the cover is located at the bottom left of the PinePhone with the back cover facing the user.
      Ask FixBot
    1. Pine64 PinePhone Battery Replacement, Battery: step 3, image 1 of 1
      • Using a fingernail, press into the bottom divot and remove the battery from the phone.
      Ask FixBot
4 other people completed this guide.
1 Guide Comment
I have all ready done this and my Pinephone doesn't work. It seems that I wasted a lot of money on a piece of junk and it's best for me not to buy another Pine64 product and convince as many people as possible not to do business with Pine64.
GunnyGee - Reply Share
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 94
All Time: 4,630
