Pine64 PinePhone Back Cover Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
85
All Time:
1,785
Comments: 0
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you how to access the internals of your Pine64 PinePhone. You will be able to access the following by opening the back cover
  • Micro SD card slot
  • Nano SIM slot
  • Battery (3000mAh)
Before you add or remove anything into the slots, please ensure your Pine64 PinePhone is powered off.
    1. Pine64 PinePhone Back Cover Replacement, Place the device facing down: step 1, image 1 of 2 Pine64 PinePhone Back Cover Replacement, Place the device facing down: step 1, image 2 of 2
      • Place the device face down on a non-scratch surface.
      • Ensure the device is powered off before removing the case as removing the battery or making internal changes could cause physical or hardware damage to the phone
      Ask FixBot
    2. Pine64 PinePhone Back Cover Replacement, Remove the back cover: step 2, image 1 of 1
      • Using a fingernail pry open the back cover off with the bottom left indent.
      • A notch to easily remove the cover is located at the bottom left of the PinePhone with the back cover facing the user.
      Ask FixBot
5 other people completed this guide.
Kristen Gismondi
109,712 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,907 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 85
All Time: 1,785
