Up to 20% off select tools
Picture Frame Matting Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
20
Past 30 Days:
109
All Time:
1,146
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Replacing warped, damaged, or discolored matting in a picture frame is a relatively simple process that most people can accomplish at home with just a couple tools. This quick project can be completed in just under half an hour. Work carefully, as fixing matting involves handling glass.
    1. Picture Frame Matting Replacement, Picture Frame Matting: step 1, image 1 of 1
      • Place the picture frame face down on a clean surface.
      Ask FixBot
    2. Picture Frame Matting Replacement: step 2, image 1 of 1
      • Use a spudger to rotate all of the frame’s backing clips away from the frame.
      Ask FixBot
    3. Picture Frame Matting Replacement: step 3, image 1 of 2 Picture Frame Matting Replacement: step 3, image 2 of 2
      • Remove the backing by lifting it up and away using a spudger.
      Ask FixBot
    4. Picture Frame Matting Replacement: step 4, image 1 of 1
      • Carefully remove the picture and old matting from the frame.
      • You can leave the glass in the frame.
      Ask FixBot
    5. Picture Frame Matting Replacement: step 5, image 1 of 1
      • Place the new matting into the frame and directly onto the glass.
      • Be careful while working around the glass to avoid self-injury or damaging the item.
      Ask FixBot
    6. Picture Frame Matting Replacement: step 6, image 1 of 2 Picture Frame Matting Replacement: step 6, image 2 of 2
      • Position the picture properly and place it on the new matting.
      • Make sure there are no gaps between the edge of the picture and the matting.
      • Carefully place a couple of small pieces of clear tape on the picture and the new matting to hold it in place.
      Ask FixBot
    7. Picture Frame Matting Replacement: step 7, image 1 of 1
      • Place the backing on top of the matting in the frame.
      Ask FixBot
    8. Picture Frame Matting Replacement: step 8, image 1 of 2 Picture Frame Matting Replacement: step 8, image 2 of 2
      • Rotate the backing clips under the frame to secure it.
      Ask FixBot
Finish Line
Author
with
Leah
160 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 109
All Time: 1,146
