Introduction
Use this guide to remove and replace the clutch on a Piaggio Ciao without a variator. The clutch connects the engine to the drive system, and removing it lets you service or replace the clutch shoes, clutch bell, washers, or spacer. This procedure shows how to remove the clutch without a pneumatic impact wrench by locking the crankshaft with a piston stop. Don't wedge a screwdriver into the flywheel to hold it still.
Step 1 Prepare the moped
Gather a spark plug wrench, a piston stop, a 50 cent coin, and a 17 mm combination wrench.
Step 2 Remove the side cover
Use a coin about the size of a 50 cent coin to unlock the three side-cover pins by turning each pin 90 degrees.
Move the pedal arm downward to access the lower pin.
Press the lower pin inward and turn it 90 degrees.
Remove the side cover from the clutch side of the moped.
Step 3 Choose the correct crankshaft lock
Use a piston stop to lock the crankshaft safely and avoid damaging the flywheel or engine.
Step 4 Install the piston stop
Pull the spark plug cap off the spark plug.
Use a spark plug wrench to unscrew the spark plug counterclockwise.
Thread the piston stop into the spark plug hole by hand.
Step 5 Remove the clutch nut
Use a 17 mm combination wrench to loosen the clutch nut counterclockwise.
Finish unscrewing the nut by hand.
Remove the safety washer.
Step 6 Remove the clutch assembly
Remove the washer from the crankshaft.
Remove the clutch shoes from the crankshaft.
Slide the clutch bell off the crankshaft.
Slide the spacer off the crankshaft last.
Install the replacement clutch and removed parts in reverse order. Remove the piston stop, reinstall the spark plug, attach the spark plug cap, and lock the side-cover pins before starting the engine. Repair didn't go as planned? Ask our Answers community for help.
