Photive Rain Battery Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
82
All Time:
980
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 40 minutes - 1 hour
Difficulty: Difficult
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
Use this guide to replace a failed battery in the Photive Rain.
Tools
    1. Photive Rain Battery Replacement, Back Panel: step 1, image 1 of 1
      • Turn the speaker off before disassembling.
      • Remove the suction cup from its groove by twisting and turning it.
      Ask FixBot
    2. Photive Rain Battery Replacement: step 2, image 1 of 1
      • Remove the four 8.5 mm screws from the back panel of the speaker by using the Phillips #1 Screwdriver.
      • Remove back panel
      Ask FixBot
    1. Photive Rain Battery Replacement, Battery: step 3, image 1 of 2 Photive Rain Battery Replacement, Battery: step 3, image 2 of 2
      • Remove the plastic cover in front of the battery slot.
      • Unscrew all the 8.5mm screws that hold the cover to the slot.
      • Separate the battery from the back panel as shown in photograph 3.
      • Caution: manipulation of the device while the battery is still connected to the motherboard may result in electric shock.
      Ask FixBot
    2. Photive Rain Battery Replacement: step 4, image 1 of 1
      • Remove the battery from the motherboard.
      • Use a soldering pen to remove the solder connecting the battery wires to the motherboard.
      • Click here to access the iFixit Soldering Guide. This will provide a safe and instructive manual on the usage of soldering pens.
      Ask FixBot
2 other people completed this guide.
abcdef ghijk
723 Reputation
4 Guides authored
IUPUI, Team 1-4, Harley Spring 2016 Member of IUPUI, Team 1-4, Harley Spring 2016
IUPUI-HARLEY-S16S1G4
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 82
All Time: 980
