Photive Hydra Speaker Replacement
  1. Photive Hydra Speaker Replacement, Face Plate and Back Plate: step 1, image 1 of 1
    • Unscrew all twelve Hex Head 1.5 (Length-3/8", Head- 1/8") screws using a 1.5mm hex screwdriver.
    Ask FixBot
  2. Photive Hydra Speaker Replacement: step 2, image 1 of 2 Photive Hydra Speaker Replacement: step 2, image 2 of 2
    • Use a plastic opening tool to pry off the face plate.
    Ask FixBot
  3. Photive Hydra Speaker Replacement: step 3, image 1 of 1
    • Remove the rubber casing by using your fingers to pull off. Be sure not tear or rip rubber casing.
    Ask FixBot
  4. Photive Hydra Speaker Replacement: step 4, image 1 of 1
    • Flip the device upside down and remove all eight Phillips (Length-3/8", Head-1/8") Screws using a standard #1 Phillips screwdriver.
    Ask FixBot
  5. Photive Hydra Speaker Replacement: step 5, image 1 of 2 Photive Hydra Speaker Replacement: step 5, image 2 of 2
    • Use plastic opening tool to pry off back plate.
    • Move the plastic opening tool along the the device to further pry open the device.
    • Be careful when taking this plate off. You may accidentally damage the water proof seal.
    Ask FixBot
  6. Photive Hydra Speaker Replacement, Speaker: step 6, image 1 of 2 Photive Hydra Speaker Replacement, Speaker: step 6, image 2 of 2
    • Identify the two Phillips (Length-5/16" Head-1/8") screws holding the speaker in place and remove them.
    Ask FixBot
  7. Photive Hydra Speaker Replacement: step 7, image 1 of 1
    • Remove the bracket holding the speaker in place.
    Ask FixBot
  8. Photive Hydra Speaker Replacement: step 8, image 1 of 1
    • Disconnect the wires that are connected from the speaker to the motherboard.
    Ask FixBot
  9. Photive Hydra Speaker Replacement: step 9, image 1 of 3 Photive Hydra Speaker Replacement: step 9, image 2 of 3 Photive Hydra Speaker Replacement: step 9, image 3 of 3
    • After all extra components are out of the way, you will need to remove the adhesive holding the speaker using either a heating gun or the iOpener kit (both can be purchased under the Parts and Tools Store section of the menu bar). Once that is completed, replace the broken speaker with the new, functional speaker.
    Ask FixBot
  10. Photive Hydra Speaker Replacement: step 10, image 1 of 2 Photive Hydra Speaker Replacement: step 10, image 2 of 2
    • Identify the four Phillips (Length-5/16", Head-1/8") screws holding the speaker housing (below the battery) and remove them.
    Ask FixBot
  11. Photive Hydra Speaker Replacement: step 11, image 1 of 1
    • Identify motherboard.
    Ask FixBot
  12. Photive Hydra Speaker Replacement: step 12, image 1 of 1
    • Disconnect highlighted electrical cords.
    Ask FixBot
  13. Photive Hydra Speaker Replacement: step 13, image 1 of 1
    • Disconnect second highlighted electrical cord.
    Ask FixBot
  14. Photive Hydra Speaker Replacement: step 14, image 1 of 1
    • Pull motherboard up and away in order to remove it.
    Ask FixBot
  15. Photive Hydra Speaker Replacement: step 15, image 1 of 1
    • Identify the two Phillips (Length-5/16", Head-1/8") screws holding the speaker in place and remove them.
    Ask FixBot
  16. Photive Hydra Speaker Replacement: step 16, image 1 of 3 Photive Hydra Speaker Replacement: step 16, image 2 of 3 Photive Hydra Speaker Replacement: step 16, image 3 of 3
    • Upon removing the plastic bracket, you will need to remove the adhesive using either a heating gun or the iOpener kit (both can be purchased under the Parts and Tools Store section of the menu bar) that is holding the speaker in place. Once that is completed, replace the broken speaker with a new, functional speaker.
    Ask FixBot
Andrew Chase
355 Reputation
3 Guides authored
USF Tampa, Team 11-3, Cheng Spring 2016 Member of USF Tampa, Team 11-3, Cheng Spring 2016
USFT-CHENG-S16S11G3
5 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 30
All Time: 1,096
