Up to 20% off select tools
Phone Buttons Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
134
All Time:
1,623
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide requires basic disassembly skills to get inside the phone. Allowing you to pull out and then realign the buttons.
    1. Phone Buttons Replacement, Battery: step 1, image 1 of 2 Phone Buttons Replacement, Battery: step 1, image 2 of 2
      • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
      Ask FixBot
    2. Phone Buttons Replacement: step 2, image 1 of 3 Phone Buttons Replacement: step 2, image 2 of 3 Phone Buttons Replacement: step 2, image 3 of 3
      • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
      Ask FixBot
    3. Phone Buttons Replacement: step 3, image 1 of 3 Phone Buttons Replacement: step 3, image 2 of 3 Phone Buttons Replacement: step 3, image 3 of 3
      • When reassembling, align the notch on the battery panel with the slot on the phone.
      Ask FixBot
    1. Phone Buttons Replacement, Buttons: step 4, image 1 of 2 Phone Buttons Replacement, Buttons: step 4, image 2 of 2
      • Remove 4 13.8mm screws holding the device back using a Phillips #1 screw driver.
      Ask FixBot
    2. Phone Buttons Replacement: step 5, image 1 of 3 Phone Buttons Replacement: step 5, image 2 of 3 Phone Buttons Replacement: step 5, image 3 of 3
      • Removed 1 4.8mm phillips head screw with a #0 Phillips head screw driver and lift away battery back being conscientious of wires.
      Ask FixBot
    3. Phone Buttons Replacement: step 6, image 1 of 2 Phone Buttons Replacement: step 6, image 2 of 2
      • Carefully remove the button board to gain access to the buttons.
      Ask FixBot
    4. Phone Buttons Replacement: step 7, image 1 of 2 Phone Buttons Replacement: step 7, image 2 of 2
      • Carefully remove each button from the baby phone.
      • When handling buttons be sure not to misplace the button contacts.
      Ask FixBot
Author
with
tellocordova
342 Reputation
2 Guides authored
USF Tampa, Team 2-4, Sullivan Fall 2015 Member of USF Tampa, Team 2-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G4
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 134
All Time: 1,623
