Phone Battery Doubling Technique
Views: 132K
View statistics:
Past 24 Hours:
16
Past 7 Days:
127
Past 30 Days:
765
All Time:
131,647
Comments: 69
7 comments on steps, 62 guide comments.
Go to guide comments
Completed: 152
152 people have marked this guide "completed." Will you be next?
Favorites: 141
141 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes
Difficulty: Very difficult
Community-Contributed Guide
Introduction
Go to step 1 ↓
Smartphones are very power hungry. A stock battery will last at most one day or less under normal usage. This guide will show you how to double your battery. Double time, double fun.
Notice:
Playing with Lithium-ion battery has some risk. If you don't have the basic skill and knowledge, STOP!
Modifying Lithium batteries might violate laws in your country or region. It's all your own responsibility!
FAQs (possibly)
Q: Can I mix batteries, one new and the other old?
A: Short answer: YES! Long answer: Google it.
Q: Can I do this on non-Samsung phone/battery?
A: Yes. This Samsung Galaxy S Duos / S7562 is just an example. Almost any phone, which you can cut or rebuild the back case, can load more batteries than it's designed to.
Q: The best way to balance voltage between batteries?
A: My opinion: Discharge them to below 3.5V or use them until auto cut off. discharged battery has higher impedance and less energy, both are good for safety.
Q: What should I do when SHTF?
A: (not likely to happen if you follow this guide) Cut the wire if you have time and right tool. Drop the batt into water and step back. Inform people nearby. Do not touch the batt until it cooled off.
    1. Phone Battery Doubling Technique, Phone Battery Doubling Technique: step 1, image 1 of 1
      • WARNING: Soft-shell lithium-ion batteries are fragile. Damaging the batteries may result in spontaneous combustion.
      • First things first. Double batteries to double the capacity. There's no magic!
      Ask FixBot
    2. Phone Battery Doubling Technique: step 2, image 1 of 3 Phone Battery Doubling Technique: step 2, image 2 of 3 Phone Battery Doubling Technique: step 2, image 3 of 3
      • Peel skin off, but not all the way off, from ONE battery.
      • Slice some skin off from the other. both sides. Until the black plastic PCB cover and be easily removed.
      Ask FixBot
    3. Phone Battery Doubling Technique: step 3, image 1 of 1
      • Put 2 batteries together and aligned, belly to belly. Bind them with the peeled skin.
      • Not too tight!
      • Remove both black plastic PCB covers.
      Ask FixBot
    4. Phone Battery Doubling Technique: step 4, image 1 of 2 Phone Battery Doubling Technique: step 4, image 2 of 2
      • Before bridge 2 batteries together, ensure voltage difference between them less than 50mV. New batteries will very likely have about 3.9V voltage, and varies very little.
      • Bridge one B+ to anotherB+ first. Use soldering iron and solder.
      • Then, P- to P-.
      • Leave Both B- open!
      • One more WARNING! Be very careful with B- test point. DO NOT MESS WITH THEM. B- are not protected by "Protection Circuits". Do NOT bridge B-, unless you know what you don't know!
      • Of course. NEVER short-circuit any B- to any B+, or P- to B+, or P- to B-!
      Ask FixBot
    5. Phone Battery Doubling Technique: step 5, image 1 of 2 Phone Battery Doubling Technique: step 5, image 2 of 2
      • Cut 2 notches on each plastic PCB covers. At the position of bridging wires, and faces each other. So the wires won't lift the PCB covers.
      • These are not quite finished.
      • These are what I'm talking about.
      • Put both PCB covers back. If you bond batteries too tight, may need to loose a little bit, then tighten again later.
      Ask FixBot
    6. Phone Battery Doubling Technique: step 6, image 1 of 1
      • Use the skin of the peeled bat to fully bond them.
      • Cover the notches and wires with some tape. Shown PI/Kapton tape will be the best choice, anything thin enough and isolate is ok.
      • The skin is a little short for 2 cells. The exposed metal should be covered also. They are the positive terminal. You don't wanna short-circuit something, do you? (not yet covered in these photos)
      Ask FixBot
    7. Phone Battery Doubling Technique: step 7, image 1 of 3 Phone Battery Doubling Technique: step 7, image 2 of 3 Phone Battery Doubling Technique: step 7, image 3 of 3
      • Double battery vs single battery. :-P
      • The back case won't fit double battery. Cut them the way you like.
      • (Not quite) Finished. Maybe I should 3D print some extra cover and glue it to the back case.
      • Actually I did 3D print a frame, and glued a trimmed RFID card as back cover. They work well!
      Ask FixBot
Double power, double juice.
152 other people completed this guide.
Terrance
7,099 Reputation
19 Guides authored
62 Guide Comments
Good idea thanks :)
kaandonmeztf - Reply Share
Wow, i dont see pages like this anywhere else, i have a xolo phone, in india, its battery dosent have any b+/- or p+/- terminals, it just has + - and the middle one, can i wire + and - in parellel to get the doubled MAH?
Inzemam Zahidi - Reply Share
No no no thats is doubling the voltage and mah u just want to double mah. Because u double both and u now have a fried phone
jeremiah gyles - Reply Share
In parellel, but only if two batteries are within very few mV of each other. They MUST be same mAH, or you will kill lower rated battery. First cut thin plastic or fireproof cardboard spacer, and place it between cells. Tape alined cells. Desolder top charging board from battery. Remove black plastic from top cell. Solder tabs + to +, then - to -. Nip lower black plastic, so tabs can fit under single charging board. Cover top battery tabs with tape or hot glue. Install pack same as you would single battery. Plug in phone charger. Fully charge battery pack, and enjoy. You now have a 1S2P 3.7 LiPo battery.
Удачи!
- Александр Борисович Мельников
Александр Мельников - Reply Share
Actually, paralleling batteries. Does not necessarily require them to be same capacity (if within reasonable range, e.g. 1Ah + 3Ah, is ok, 500mAh + 100Ah, probably not). But requires them be same voltage spec, 4.35V // 4.35V is ok, 4.35V // 4.25V is not good.
Terrance - Reply Share
Past 24 Hours: 16
Past 7 Days: 127
Past 30 Days: 765
All Time: 131,647
