Philips TAS7505 Speaker Replacement
    1. Philips TAS7505 Speaker Replacement, Speaker: step 1, image 1 of 3 Philips TAS7505 Speaker Replacement, Speaker: step 1, image 2 of 3 Philips TAS7505 Speaker Replacement, Speaker: step 1, image 3 of 3
      • Using the opening tool, remove the rubber padding from the bottom of the speaker.
      • The rubber padding is glued on and may require reapplying adhesive to re-assemble.
      Ask FixBot
    2. Philips TAS7505 Speaker Replacement: step 2, image 1 of 3 Philips TAS7505 Speaker Replacement: step 2, image 2 of 3 Philips TAS7505 Speaker Replacement: step 2, image 3 of 3
      • Using the Philips screwdriver head #0, remove all four screws holding the plastic plate in place.
      • Use the same opening tool from the previous step to remove the plastic plate.
      Ask FixBot
    3. Philips TAS7505 Speaker Replacement: step 3, image 1 of 3 Philips TAS7505 Speaker Replacement: step 3, image 2 of 3 Philips TAS7505 Speaker Replacement: step 3, image 3 of 3
      • Now that you have removed this cover, there is another cover. This cover has a total of 9 screws that can be removed with the Philips 0-bit screwdriver bit.
      • Once all these screws are removed, you can take off the cover
      Ask FixBot
    4. Philips TAS7505 Speaker Replacement: step 4, image 1 of 3 Philips TAS7505 Speaker Replacement: step 4, image 2 of 3 Philips TAS7505 Speaker Replacement: step 4, image 3 of 3
      • Squeeze the white connector on the bottom to release a clip that is hidden from sight. This will allow it to be wiggled free.
      • Remove the battery from the speaker by disconnecting the white connector from the motherboard.
      Ask FixBot
    5. Philips TAS7505 Speaker Replacement: step 5, image 1 of 3 Philips TAS7505 Speaker Replacement: step 5, image 2 of 3 Philips TAS7505 Speaker Replacement: step 5, image 3 of 3
      • Find the rubber flap that covers the USB-A and USB-C port
      • Pull on the rubber flap, it should come out whole as shown in the second image
      • Once taken out the rubber flap, pull the interior of the speaker
      Ask FixBot
    6. Philips TAS7505 Speaker Replacement: step 6, image 1 of 2 Philips TAS7505 Speaker Replacement: step 6, image 2 of 2
      • Once you have the speaker body out, unscrew the four screws holding the speaker down
      • Use Philips screwdriver head #0
      Ask FixBot
    7. Philips TAS7505 Speaker Replacement: step 7, image 1 of 1
      • Pull the motherboard out then disconnect the white connector of the speaker by wiggling it back and forth.
      • See the motherboard repair guide for more in-depth instructions on this part
      Ask FixBot
    8. Philips TAS7505 Speaker Replacement: step 8, image 1 of 3 Philips TAS7505 Speaker Replacement: step 8, image 2 of 3 Philips TAS7505 Speaker Replacement: step 8, image 3 of 3
      • The speaker will look like this if you have followed the steps correctly
      Ask FixBot
Frederick Jimenez
277 Reputation
2 Guides authored
CSU Los Angeles, Team 5-2, Adachi Fall 2022 Member of CSU Los Angeles, Team 5-2, Adachi Fall 2022
CSULA-ADACHI-F22S5G2
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 48
All Time: 1,567
