Philips Sonicare does not start
Views: 15K
View statistics:
Past 24 Hours:
23
Past 7 Days:
101
Past 30 Days:
392
All Time:
14,625
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 40 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓
The toothbrush can no longer be switched on using the power button. The toothbrush does not respond to the top switch. The mode switch works without problems.
Here's how to find and fix the error.
    1. Philips Sonicare does not start, Board repair: step 1, image 1 of 1
      • The starting point is an already opened toothbrush.
      Ask FixBot
    2. Philips Sonicare does not start, Check conducting traces: step 2, image 1 of 1
      • Check whether there is a problem connecting the button to the electronics
      • If an increased resistance is measured, the conductor track is defective and must be replaced.
      Ask FixBot
    3. Philips Sonicare does not start, Replace conductor: step 3, image 1 of 1
      • If there is a bad trace, I recommend repairing both lines (marked red here) with insulated wires.
      • when everything is soldered, the toothbrush can be tested. When everything works again, the new wires still have to be glued so that they don't come loose.
      Ask FixBot
After successful repair, the toothbrush can be put back together.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Johannes K.
364 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 23
Past 7 Days: 101
Past 30 Days: 392
All Time: 14,625
