Philips Sonicare ProtectiveClean 6500 Motor Replacement
  1. Philips Sonicare ProtectiveClean 6500 Motor Replacement, Internal Assembly: step 1, image 1 of 3 Philips Sonicare ProtectiveClean 6500 Motor Replacement, Internal Assembly: step 1, image 2 of 3 Philips Sonicare ProtectiveClean 6500 Motor Replacement, Internal Assembly: step 1, image 3 of 3
    • Pry the bottom cap away from the toothbrush body.
    • If it is not easy to open, these alternative instructions may help you.
    • Pry the bottom cap away from the toothbrush body until it releases.
    • Remove the bottom cap by hand.
    Ask FixBot
  2. Philips Sonicare ProtectiveClean 6500 Motor Replacement: step 2, image 1 of 2 Philips Sonicare ProtectiveClean 6500 Motor Replacement: step 2, image 2 of 2
    • Use a metal spudger to release the two retaining clips inside the device.
    • The clips release when pried inward.
    Ask FixBot
  3. Philips Sonicare ProtectiveClean 6500 Motor Replacement: step 3, image 1 of 2 Philips Sonicare ProtectiveClean 6500 Motor Replacement: step 3, image 2 of 2
    • Slide the internal assembly out of the chassis.
    Ask FixBot
  4. Philips Sonicare ProtectiveClean 6500 Motor Replacement, Motor: step 4, image 1 of 2 Philips Sonicare ProtectiveClean 6500 Motor Replacement, Motor: step 4, image 2 of 2
    • Use an opening tool to gently pry the ribbon cable away from metal motor chassis.
    Ask FixBot
  5. Philips Sonicare ProtectiveClean 6500 Motor Replacement: step 5, image 1 of 2 Philips Sonicare ProtectiveClean 6500 Motor Replacement: step 5, image 2 of 2
    • Locate the twisted copper wires feeding from the top of the motor to the upper corner of motherboard.
    • Desolder the contact points.
    • Soldering can cause burns and fires. Always solder in a well-ventilated workspace.
    Ask FixBot
  6. Philips Sonicare ProtectiveClean 6500 Motor Replacement: step 6, image 1 of 2 Philips Sonicare ProtectiveClean 6500 Motor Replacement: step 6, image 2 of 2
    • Desolder the two connections.
    Ask FixBot
  7. Philips Sonicare ProtectiveClean 6500 Motor Replacement: step 7, image 1 of 2 Philips Sonicare ProtectiveClean 6500 Motor Replacement: step 7, image 2 of 2
    • Turn the assembly over and remove the Phillips screw.
    Ask FixBot
  8. Philips Sonicare ProtectiveClean 6500 Motor Replacement: step 8, image 1 of 3 Philips Sonicare ProtectiveClean 6500 Motor Replacement: step 8, image 2 of 3 Philips Sonicare ProtectiveClean 6500 Motor Replacement: step 8, image 3 of 3
    • Pull the motherboard and motor gently away from the motor chassis.
    Ask FixBot
  9. Philips Sonicare ProtectiveClean 6500 Motor Replacement: step 9, image 1 of 2 Philips Sonicare ProtectiveClean 6500 Motor Replacement: step 9, image 2 of 2
    • Use a pointed tool to push in the tabs on either side of the white assembly .
    • Pull the wire carrier off of motor chassis.
    • Swap it to the new motor chassis.
    Ask FixBot
Liam Casto
354 Reputation
3 Guides authored
IUPUI, Team 1-4, Harley Spring 2024 Member of IUPUI, Team 1-4, Harley Spring 2024
IUPUI-HARLEY-S24S1G4
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 51
All Time: 719
