Philips Sonicare ProtectiveClean 6500 Battery Replacement
  1. Philips Sonicare ProtectiveClean 6500 Battery Replacement, Internal Assembly: step 1, image 1 of 3 Philips Sonicare ProtectiveClean 6500 Battery Replacement, Internal Assembly: step 1, image 2 of 3 Philips Sonicare ProtectiveClean 6500 Battery Replacement, Internal Assembly: step 1, image 3 of 3
    • Pry the bottom cap away from the toothbrush body.
    • If it is not easy to open, these alternative instructions may help you.
    • Pry the bottom cap away from the toothbrush body until it releases.
    • Remove the bottom cap by hand.
    Ask FixBot
  2. Philips Sonicare ProtectiveClean 6500 Battery Replacement: step 2, image 1 of 2 Philips Sonicare ProtectiveClean 6500 Battery Replacement: step 2, image 2 of 2
    • Use a metal spudger to release the two retaining clips inside the device.
    • The clips release when pried inward.
    Ask FixBot
  3. Philips Sonicare ProtectiveClean 6500 Battery Replacement: step 3, image 1 of 2 Philips Sonicare ProtectiveClean 6500 Battery Replacement: step 3, image 2 of 2
    • Slide the internal assembly out of the chassis.
    Ask FixBot
  4. Philips Sonicare ProtectiveClean 6500 Battery Replacement, Battery: step 4, image 1 of 1
    • Use an opening tool to gently pry up the battery.
    • Remove the battery.
    Ask FixBot
Liam Casto
354 Reputation
3 Guides authored
IUPUI, Team 1-4, Harley Spring 2024 Member of IUPUI, Team 1-4, Harley Spring 2024
IUPUI-HARLEY-S24S1G4
3 Members
6 Guides authored
2 Guide Comments
Hello, thanks for your tutorial!
Is there others Sonicare models like this one where you don't have to desold the battery ?
Julien CHAZAL - Reply Share
It doesn’t appear you have to desolder the battery with this model. I think the diamond clean does require desoldering though.
Jacob Poole - Reply Share
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 52
All Time: 869
