Philips Sonicare FlexCare Spring Replacement
Views: 6.6K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
97
All Time:
6,649
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This guide will help you replace the spring in your Philips Sonicare FlexCare toothbrush.
Tools
  • Metal Spudger
    $2.99
    4.9
  • Spudger
    4.9
    1. Philips Sonicare FlexCare Spring Replacement, Spring: step 1, image 1 of 1
      • Pull the brush head away from the handle to remove it.
      Ask FixBot
    2. Philips Sonicare FlexCare Spring Replacement: step 2, image 1 of 2 Philips Sonicare FlexCare Spring Replacement: step 2, image 2 of 2
      • Push the flat edge of a nylon or metal spudger between the seal and the toothbrush body and pry it up. Do this on each side until the seal is partially sticking out on all sides.
      Ask FixBot
    3. Philips Sonicare FlexCare Spring Replacement: step 3, image 1 of 1
      • Apply pressure to the shaft by pressing it against a firm and flat surface. Continue to apply pressure until the interior electronics are exposed.
      Ask FixBot
    4. Philips Sonicare FlexCare Spring Replacement: step 4, image 1 of 1
      • Grab the circular, plastic base with the o-ring and pull it outward.
      Ask FixBot
    5. Philips Sonicare FlexCare Spring Replacement: step 5, image 1 of 1
      • Pull off the black rubber ring with a metal or nylon spudger until it clears the metal piece that holds it in place. Pull the ring out.
      Ask FixBot
    6. Philips Sonicare FlexCare Spring Replacement: step 6, image 1 of 1
      • Remove the spring from the rubber ring and replace it with the new spring.
      Ask FixBot
4 other people completed this guide.
Joanna Moraza
2,022 Reputation
2 Guides authored
Cal Poly, Team 4-6, Maness Spring 2015 Member of Cal Poly, Team 4-6, Maness Spring 2015
CPSU-MANESS-S15S4G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 97
All Time: 6,649
